Part Number: TMS570LC4357-EP
Other Parts Discussed in Thread: TMS570LC4357
For TMS570LC43XX HDK we are facing linker issues with GHS tools. Are these ICs and tools compatible with GHS tools (GreenHills) ? Please suggest solution.
Hi Aniket,
The GreenHills web page mentions ARM Cortex R5F, but does not mention the TMS570 family. I suggest you contact them. If they support the standard TMS570LC4357, the support can be used for the EP product as well. You need support that will generate and program the ECC values with the code as this device will not run without proper ECC values programmed into the flash.
The HDK has a built-in XDS100V2 emulator, and LC43x -EP is supported by TI CCS and several other IDEs for example IAR.
