Part Number: LAUNCHXL2-570LC43
Other Parts Discussed in Thread: TMS570LC4357
Customer is trying to configure the TMS570LC4357 Launchpad please see details below.
I'm is trying to configure the TMS570LC4357 LaunchPad example example_mibspiDMA.c with the MIBSPI charlen set to 8 bits and use the DMA to transfer the received data to an 8 bit array. The example works correctly with 16 bit charlen and the example code. I don't want to store twice the data required so I just want to store the 8 LSB from the mibspiRAM1 received data into a second array. This post suggests this is possible: https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/870652/rm57l843-mib-spi-with-dma-support but changing the byte offsets hasn't been successful. Could you give me more information on how to implement this? I've attached my latest attempt.
/** @file HL_sys_main.c
* @brief Application main file
* @date 11-Dec-2018
* @version 04.07.01
* This file contains an empty main function,
* which can be used for the application.
* Copyright (C) 2009-2018 Texas Instruments Incorporated - www.ti.com
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
/* USER CODE END */
/* Include Files */
#include "HL_sys_common.h"
/* USER CODE BEGIN (1) */
#include "HL_mibspi.h"
#include "HL_sys_dma.h"
// C Library
#include <stdio.h>
/* example data Pattern configuration */
#define D_SIZE 128
void loadDataPattern(uint32 psize, uint16* pptr);
void mibspiEnableInternalLoopback(mibspiBASE_t *mibspi);
void dmaConfigCtrlPacket(uint32 sadd,uint32 dadd,uint32 dsize);
void mibspiDmaConfig(mibspiBASE_t *mibspi,uint32 channel, uint32 txchannel, uint32 rxchannel);
#pragma SET_DATA_SECTION(".sharedRAM")
uint16 TXDATA[D_SIZE]; /* transmit buffer in sys ram */
uint8 RXDATA[D_SIZE]= {0}; /* receive buffer in sys ram */
#pragma SET_DATA_SECTION()
g_dmaCTRL g_dmaCTRLPKT1, g_dmaCTRLPKT2; /* dma control packet configuration stack */
/* USER CODE END */
/** @fn void main(void)
* @brief Application main function
* @note This function is empty by default.
* This function is called after startup.
* The user can use this function to implement the application.
/* USER CODE BEGIN (2) */
/* USER CODE END */
int main(void)
/* USER CODE BEGIN (3) */
/* - creating a data chunk in system ram to start with ... */
loadDataPattern(D_SIZE,&TXDATA[0]);
/* - initializing mibspi - enabling tg 0 , length 127 (halcogen file)*/
mibspiInit();
/* - enabling loopback ( this is to emulate data transfer without external wires */
mibspiEnableInternalLoopback(mibspiREG1);
/* - configuring dma control packets */
g_dmaCTRLPKT1.SADD = (uint32)TXDATA; /* source address */
g_dmaCTRLPKT1.DADD = (uint32)&(mibspiRAM1->tx[0].data); /* destination address */
g_dmaCTRLPKT1.CHCTRL = 0; /* channel control */
g_dmaCTRLPKT1.FRCNT = 1; /* frame count */
g_dmaCTRLPKT1.ELCNT = D_SIZE; /* element count */
g_dmaCTRLPKT1.ELDOFFSET = 4; /* element destination offset */
g_dmaCTRLPKT1.ELSOFFSET = 0; /* element source offset */
g_dmaCTRLPKT1.FRDOFFSET = 0; /* frame destination offset */
g_dmaCTRLPKT1.FRSOFFSET = 0; /* frame destination offset */
g_dmaCTRLPKT1.PORTASGN = PORTA_READ_PORTB_WRITE;
g_dmaCTRLPKT1.RDSIZE = ACCESS_16_BIT; /* read size */
g_dmaCTRLPKT1.WRSIZE = ACCESS_16_BIT; /* write size */
g_dmaCTRLPKT1.TTYPE = FRAME_TRANSFER ; /* transfer type */
g_dmaCTRLPKT1.ADDMODERD = ADDR_INC1; /* address mode read */
g_dmaCTRLPKT1.ADDMODEWR = ADDR_OFFSET; /* address mode write */
g_dmaCTRLPKT1.AUTOINIT = AUTOINIT_ON; /* autoinit */
g_dmaCTRLPKT2.SADD = (uint32)&(mibspiRAM1->rx[0].data); /* source address */
g_dmaCTRLPKT2.DADD = (uint32)RXDATA; /* destination address */
g_dmaCTRLPKT2.CHCTRL = 0; /* channel control */
g_dmaCTRLPKT2.FRCNT = 1; /* frame count */
g_dmaCTRLPKT2.ELCNT = D_SIZE; /* element count */
g_dmaCTRLPKT2.ELDOFFSET = 0; /* element destination offset */
g_dmaCTRLPKT2.ELSOFFSET = 4; /* element source offset */
g_dmaCTRLPKT2.FRDOFFSET = 0; /* frame destination offset */
g_dmaCTRLPKT2.FRSOFFSET = 0; /* frame destination offset */
g_dmaCTRLPKT2.PORTASGN = PORTB_READ_PORTA_WRITE;
g_dmaCTRLPKT2.RDSIZE = ACCESS_8_BIT; /* read size */
g_dmaCTRLPKT2.WRSIZE = ACCESS_8_BIT; /* write size */
g_dmaCTRLPKT2.TTYPE = FRAME_TRANSFER ; /* transfer type */
g_dmaCTRLPKT2.ADDMODERD = ADDR_OFFSET; /* address mode read */
g_dmaCTRLPKT2.ADDMODEWR = ADDR_INC1; /* address mode write */
g_dmaCTRLPKT2.AUTOINIT = AUTOINIT_ON; /* autoinit */
/* upto 32 control packets are supported. */
/* - setting dma control packets */
dmaSetCtrlPacket(DMA_CH0,g_dmaCTRLPKT2);
dmaSetCtrlPacket(DMA_CH1,g_dmaCTRLPKT1);
/* - setting the dma channel to trigger on h/w request */
dmaSetChEnable(DMA_CH0, DMA_HW);
dmaSetChEnable(DMA_CH1, DMA_HW);
/* - configuring the mibspi dma , channel 0 , tx line -0 , rxline -1 */
/* - refer to the device data sheet dma request source for mibspi tx/rx */
mibspiDmaConfig(mibspiREG1,0,0,1);
dmaEnable();
/* - start the mibspi transfer tg 0 */
mibspiTransfer(mibspiREG1,0 );
while(1){
int i =0;
while (i < 4000){
i++;
uint8 value = *(&(mibspiRAM1->rx[0].data));
printf("Address mibspiRAM1->rx[0].data: %X , value: %X \n", &(mibspiRAM1->rx[0].data), value);
value = *(&(mibspiRAM1->rx[0].data) + 1);
printf("Address 0 + 1: %X , value: %X \n", &(mibspiRAM1->rx[0].data) + 1, value);
value = *(&(mibspiRAM1->rx[0].data) + 2);
printf("Address 0 + 2: %X , value: %X \n", &(mibspiRAM1->rx[0].data) + 2, value);
value = *(&(mibspiRAM1->rx[0].data) + 3);
printf("Address 0 + 3: %X , value: %X \n", &(mibspiRAM1->rx[0].data) + 3, value);
value = *(&(mibspiRAM1->rx[0].data) + 4);
printf("Address 0 + 4: %X , value: %X \n", &(mibspiRAM1->rx[0].data) + 4, value);
printf("Address mibspiRAM1->rx[1].data: %X , value: %X \n", &(mibspiRAM1->rx[1].data), mibspiRAM1->rx[1].data);
printf("Address RXDATA 0: %X , value: %X \n", &RXDATA[0], RXDATA[0]);
printf("Address RXDATA 1: %X , value: %X \n", &RXDATA[1], RXDATA[1]);
printf("Complete: %i \n", mibspiIsTransferComplete(mibspiREG1, 0));
printf("0 - TX: %X RX: %X \n", TXDATA[0], RXDATA[0]);
printf("0 - TX: %X RX: %X \n", mibspiRAM1->tx[0].data, mibspiRAM1->rx[0].data);
printf("1 - TX: %X RX: %X \n", TXDATA[1], RXDATA[1]);
printf("1 - TX: %X RX: %X \n", mibspiRAM1->tx[1].data, mibspiRAM1->rx[1].data);
printf("2 - TX: %X RX: %X \n", TXDATA[2], RXDATA[2]);
printf("2 - TX: %X RX: %X \n", mibspiRAM1->tx[2].data, mibspiRAM1->rx[2].data);
printf("3 - TX: %X RX: %X \n", TXDATA[3], RXDATA[3]);
printf("3 - TX: %X RX: %X \n", mibspiRAM1->tx[3].data, mibspiRAM1->rx[3].data);
printf("4 - TX: %X RX: %X \n", TXDATA[4], RXDATA[4]);
printf("4 - TX: %X RX: %X \n", mibspiRAM1->tx[4].data, mibspiRAM1->rx[4].data);
printf("5 - TX: %X RX: %X \n", TXDATA[5], RXDATA[5]);
printf("5 - TX: %X RX: %X \n", mibspiRAM1->tx[5].data, mibspiRAM1->rx[5].data);
/* USER CODE END */
return 0;
/* USER CODE BEGIN (4) */
/** void mibspiEnableLoopback(mibspiBASE_t *mibspi )
* enabling internal loopback on mibspix
void mibspiEnableInternalLoopback(mibspiBASE_t *mibspi )
/* enabling internal loopback */
mibspi->GCR1 |= 1U << 16U;
/** void mibspiDmaConfig(mibspiBASE_t *mibspi,uint32 channel, uint32 txchannel, uint32 rxchannel)
* configuring mibspi dma with
* channel > mibspi dma channel number
* txchannel > transmit channel dedicated for mibspi
* rxchannel > receive channel dedicated for mibspi
uint32 bufid = D_SIZE - 1;
uint32 icount = 0;
/* setting transmit and receive channels */
mibspi->DMACTRL[channel] |= (((rxchannel<<4)|txchannel) << 16);
/* enabling transmit and receive dma */
mibspi->DMACTRL[channel] |= 0x8000C000;
/* setting Initial Count of DMA transfers and the buffer utilized for DMA transfer */
mibspi->DMACTRL[channel] |= (icount << 8) |(bufid<<24);
/** void loadDataPattern(uint32 psize, uint16* pptr)
* loading a randam data chunk into system ram
* pptr > sys ram address
* psize > chunkl size
int i;
for(i=0;i<psize;i++)
TXDATA[i] = i;
/* USER CODE END */
Thank you.
May
