Part Number: MCU-PLUS-SDK-AM243X
I modified our linker-script to place specified sections to different addresses. This worked and somehow does not work anymore. When linking I get a warning
line X: warning: no matching section
for multiple libraries and their different sections but ONLY for those libraries at all.
in fact: I am placing sections of 8 libs to different places. that means I place the .text, .rodata, .data of the libraries at different addresses. and only the sections .text, .rodata, .data of three libs are not found anymore. The other libs are fine. I used readelf -t of the LTS1.3.0 (which I use to compile and link) and the sections are definetly there.
example in linkerscript:
SECTIONS
GROUP {
.textStack:
-l "examplelib.am243x-bni.r5f.ti-arm-clang.release.lib"(.text) // works
-l "examplelib1.am243x-bni.r5f.ti-arm-clang.release.lib"(.text) // does not work
This is a really strange problem since it just does happen out of nowhere. All I did was exchanging the libs with newer ones (but as said: the sections are available).
Do you have any ideas what is happening here and how I can prevent this warning? At first steps it seems the libs are working and the stuff seems to be really linked since I can find the symbols of the libs inside the elf-file and in the debug-image in CCS.
best regards
Felix
