Part Number: TMDX570LC43HDK
After the new project is built, the RED error indicator is always on.I checked the connection below:but the supplied CMD file cannot be opened.The program cannot run after modifying flash settings.
Console always shows:CortexR5: GEL Output: Memory Map Setup for Flash @ Address 0x0CortexR5: GEL Output: Memory Map Setup for Flash @ Address 0x0 due to System Reset
链接器生成的 ECC — Hercules 安全 MCU 文档 (ti.com)
The routine on the official website can't run either.
