Part Number: TMS570LS1227
Hi All,
I try to do CAN bootloader for TMS570ls1227. Firstly I am writing bootloader code at memory map of microcontroller, then I am writing app code wit debugger where to selected address(0x10000). You can see memory status at different style at IMG_1, IMG_2, IMG_3 . Then I am generating code output as a text. After generating I wrote whole text to flash of microprocessor and code didn't work. Because of this, I found difference of text code and debug memory placement. For example 0x10000 address's data writes at end of line 2 (you can check it on IMG_5) 0x10020 address's data have written at line 327 (you can check it on IMG_4).I think code generation tool produce the code different style from the memory map order.
Can you offer anything about this? I hope, I can explained the situation as truly.
