AM2634: CPSW_MII supported on AM2634?
Part Number: AM2634
Dear Champs,
Could you please let me know if CPSW_MII can be supported on AM2634?
I found there are only supported I/F of CPSW are RGMII and RMII in AM2634 by referring datasheet as below.
But, I found MII information in the datasheet and TRM, and I'm confused if MII can be supported on AM2634 or not.
If MII can be supported on AM2634, should external OSC of 25Mhz be attached as described in the TRM?
Is there any way to use internal clock(CLK_OUT) to generate 25Mhz ref_clock for Ethernet PHY?
Thanks and Best Regards,
SI.
