Part Number: TMDSCNCD263
After compiling it last in CCS, according to explanation of "EXAMPLES_INDUSTRIAL_COMMS_ETHERCAT_SLAVE_BECKHOFF_SSC_DEMO.html", the following errors were displayed.
Please tell me the operation not to cause an error.
Description Resource Path Location Type
gmake: *** [tiescappl.o] Error 1 ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang C/C++ Problem
gmake: *** [tiesceoefoe.o] Error 1 ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang C/C++ Problem
gmake: *** [tiescutils.o] Error 1 ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang C/C++ Problem
gmake: *** No rule to make target 'C:/source/industrial_comms/ethercat_slave/beckhoff_stack/stack_sources/bootmode.c', needed by 'bootmode.o'. ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang C/C++ Problem
gmake: *** No rule to make target 'C:/source/industrial_comms/ethercat_slave/beckhoff_stack/stack_sources/coeappl.c', needed by 'coeappl.o'. ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang C/C++ Problem
gmake: *** No rule to make target 'C:/source/industrial_comms/ethercat_slave/beckhoff_stack/stack_sources/ecatappl.c', needed by 'ecatappl.o'. ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang C/C++ Problem
gmake: *** No rule to make target 'C:/source/industrial_comms/ethercat_slave/beckhoff_stack/stack_sources/ecatcoe.c', needed by 'ecatcoe.o'. ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang C/C++ Problem
gmake: *** No rule to make target 'C:/source/industrial_comms/ethercat_slave/beckhoff_stack/stack_sources/ecateoe.c', needed by 'ecateoe.o'. ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang C/C++ Problem
gmake: *** No rule to make target 'C:/source/industrial_comms/ethercat_slave/beckhoff_stack/stack_sources/ecatfoe.c', needed by 'ecatfoe.o'. ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang C/C++ Problem
gmake: *** No rule to make target 'C:/source/industrial_comms/ethercat_slave/beckhoff_stack/stack_sources/ecatslv.c', needed by 'ecatslv.o'. ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang C/C++ Problem
gmake: *** No rule to make target 'C:/source/industrial_comms/ethercat_slave/beckhoff_stack/stack_sources/eoeappl.c', needed by 'eoeappl.o'. ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang C/C++ Problem
gmake: *** No rule to make target 'C:/source/industrial_comms/ethercat_slave/beckhoff_stack/stack_sources/foeappl.c', needed by 'foeappl.o'. ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang C/C++ Problem
gmake: *** No rule to make target 'C:/source/industrial_comms/ethercat_slave/beckhoff_stack/stack_sources/mailbox.c', needed by 'mailbox.o'. ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang C/C++ Problem
gmake: *** No rule to make target 'C:/source/industrial_comms/ethercat_slave/beckhoff_stack/stack_sources/objdef.c', needed by 'objdef.o'. ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang C/C++ Problem
gmake: *** No rule to make target 'C:/source/industrial_comms/ethercat_slave/beckhoff_stack/stack_sources/sdoserv.c', needed by 'sdoserv.o'. ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang C/C++ Problem
gmake: Target 'all' not remade because of errors. ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang C/C++ Problem
invalid token at start of a preprocessor expression .ccsproject /ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang line 1185, external location: C:\ti\mcu_plus_sdk_am263x_08_02_00_28\examples\industrial_comms\ethercat_slave_beckhoff_ssc_demo\ecat_def.h C/C++ Problem
invalid token at start of a preprocessor expression .ccsproject /ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang line 1189, external location: C:\ti\mcu_plus_sdk_am263x_08_02_00_28\examples\industrial_comms\ethercat_slave_beckhoff_ssc_demo\ecat_def.h C/C++ Problem
recipe for target 'tiescappl.o' failed subdir_rules.mk /ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang/Debug line 128 C/C++ Problem
recipe for target 'tiesceoefoe.o' failed subdir_rules.mk /ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang/Debug line 135 C/C++ Problem
recipe for target 'tiescutils.o' failed subdir_rules.mk /ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang/Debug line 156 C/C++ Problem
Product SysConfig v1.11.0 is not currently installed. A compatible version 1.12.0 will be used. ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang Problem
This project contains 12 unresolved buildable linked resource(s). The project may not build as expected. ethercat_slave_beckhoff_ssc_demo_am263x-cc_r5fss0-0_freertos_ti-arm-clang project Problem
