Part Number: TM4C1294NCPDT
Good Evening!
I think that not all "ul" mean "unsigned int 32-bit" in file "TivaWare_C_Series-2.2.0.295/third_party/lwip-1.4.1/ports/tiva-tm4c129/netif/tiva-tm4c129.c". I propose to reverse changes according to patch:
--- orig/tiva-tm4c129.c 2022-07-04 13:39:26.977320128 +0200
+++ fixed/tiva-tm4c129.c 2022-07-05 01:12:08.842076073 +0200
@@ -21,7 +21,7 @@
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
* WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
- * MERCHANTABILITY AND FITNESS FOR A PARTICui32AR PURPOSE ARE DISCLAIMED. IN NO EVENT
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT
* SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
* OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
@@ -87,7 +87,7 @@
#endif
- * If necessary, set the defaui32t number of transmit and receive DMA descriptors
+ * If necessary, set the default number of transmit and receive DMA descriptors
* used by the Ethernet MAC.
@@ -328,7 +328,7 @@
ui16Val = EMACPHYRead(EMAC0_BASE, PHY_PHYS_ADDR, EPHY_MISR1);
- * Set MAC filtering options. We receive all broadcast and mui32ticast
+ * Set MAC filtering options. We receive all broadcast and multicast
* packets along with those addressed specifically for us.
EMACFrameFilterSet(EMAC0_BASE, (EMAC_FRMFILTER_HASH_AND_PERFECT |
@@ -473,8 +473,8 @@
* @param psNetif the lwip network interface structure for this ethernetif
* @param p the MAC packet to send (e.g. IP packet including MAC addresses and type)
- * @return ERR_OK if the packet coui32d be sent
- * an err_t value if the packet coui32dn't be sent
+ * @return ERR_OK if the packet could be sent
+ * an err_t value if the packet couldn't be sent
static err_t
tivaif_transmit(struct netif *psNetif, struct pbuf *p)
@@ -846,7 +846,7 @@
pDescList->pDescriptors[pDescList->ui32Read].Desc.pvBuffer1 = 0;
- /* Update the stats to show we coui32dn't allocate a pbuf. */
+ /* Update the stats to show we couldn't allocate a pbuf. */
DRIVER_STATS_INC(RXNoBufCount);
LINK_STATS_INC(link.memerr);
@@ -874,7 +874,7 @@
* @return ERR_OK if the loopif is initialized
- * ERR_MEM if private data coui32dn't be allocated
+ * ERR_MEM if private data couldn't be allocated
* any other err_t on error
err_t
@@ -952,7 +952,7 @@
#endif
/* In this case we drop through since we may need to reconfigure
- * the MAC depending upon the speed and half/fui32l-duplex settings.
+ * the MAC depending upon the speed and half/full-duplex settings.
else
@@ -986,10 +986,10 @@
ui32Config |= EMAC_CONFIG_100MBPS;
- /* Are we in fui32l- or half-duplex mode? */
+ /* Are we in full- or half-duplex mode? */
if(ui16Status & EPHY_STS_DUPLEX)
- /* Fui32l duplex. */
+ /* Full duplex. */
ui32Config |= EMAC_CONFIG_FULL_DUPLEX;
else
