Part Number: TMDSEMU110-U
Hi guys,
I bought some time ago a TMDSEMU110-U to starting developing some PRU programs to be used with Beaglebone Black/Green.
My kit came with 2 cables - one for debug and the other for aux functions and 4 adapters. One of this adapters is a CTI20 Male to ARM20-ETM that fits in the cable for the debugger and the JTag connector of the beaglebone - at least I was thinking that.
Connecting everything and trying to run some codes I'm facing the error 267. After consulting the forum I found some great clues and one of them was to check the voltage on the vref pin checking this one I could realize that this adapter is not what I was thinking about because there is no voltage on the pin5 of the adapter, so I believe I need an adapter to use this probe with beablebone.
Looking at the forum I found this post:
I will appreciate if someone could help me telling that is the issue - this adapter is not for be used between beagle and the cable, and what would be a cable/adapter I could use to do that.
Thanks a lot.
Best regards.
