Hi Champs,
I ask this for our customer.
Customers need to load the code to external FLASH. Now the method used by customers is: first use NO BOOT MODE to flash the application, and then change the boot mode to QSPI BOOT MODE to run the flashed application. This method works. But each time the boot mode is switched and reset, the code in RAM will disappear, and the customer want to know if we have a way to directly use QSPI to flash the application? It will helps a lot.
Could you please help customer check it? Thanks!
Julia
