Part Number: TMS570LS3137
Other Parts Discussed in Thread: HALCOGEN
I am trying to implement communication through mibspi1 and dma between two boards of which one is master and one is slave.
The boards are physically connected to the mibspi1 clock, somi and miso lines.
I was able to get the master board to work on its own by shorting somi and simo.
Now when I connect the slave, I can see through the oscilloscope the data on simo and the clock during the transfer, but on the slave side neither the dma interrupt nor the mibspi transfer interrupt is triggered.
Below are the HalcoGen settings for the slave:
I enabled in the VIM tab the interrupts related to dma and mibspi1, and enabled PINMUX for mibspi1.
I attach the code for master and slave.
What could be the error?
Thanks for the help.
Guglielmo Jr.
/** @file sys_main.c
* @brief Application main file
* @date 11-Dec-2018
* @version 04.07.01
* This file contains an empty main function,
* which can be used for the application.
* Copyright (C) 2009-2018 Texas Instruments Incorporated - www.ti.com
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
/* USER CODE END */
/* Include Files */
#include "sys_common.h"
/* USER CODE BEGIN (1) */
#include "mibspi.h"
#include "sys_dma.h"
#include "stdio.h"
#include "sys_core.h"
/* USER CODE END */
/** @fn void main(void)
* @brief Application main function
* @note This function is empty by default.
* This function is called after startup.
* The user can use this function to implement the application.
/* USER CODE BEGIN (2) */
void mibspiDmaConfig(mibspiBASE_t *mibspi,uint32 channel, uint32 txchannel, uint32 rxchannel);
void dmaConfigCtrlRxPacket(uint32 sadd,uint32 dadd,uint16 ElmntCnt, uint16 FrameCnt);
void dmaConfigCtrlTxPacket(uint32 sadd,uint32 dadd,uint16 ElmntCnt, uint16 FrameCnt);
void loadDataPattern1(uint32 psize, uint16* pptr);
void loadDataPattern2(uint32 psize, uint16* pptr);
#define E_COUNT 61 //4 /*Element count*/
#define F_COUNT 10 //2 /*Frame count*/
#define D_SIZE E_COUNT * F_COUNT
/* SPI1 transmit buffer in sys ram */
uint16 mibSPI1_TX_Data[D_SIZE];//= "$GPZDA,hhmmss.ss,dd,mm,yyyy,aa,bb*CS<CR><LF>$GPGLL,llll.lllll,a,yyyyy.yyyyy,b,hhmmss.ss,c,a*CS<CR><LF>$GPGSV,t,n,xx,aa,ee,zzz,cc,aa,ee,zzz,cc,aa,ee,zzz,cc,aa,ee,zzz,cc*CS<CR><LF>$GPRMC,hhmmss.ss,A,llll.lllll,A,yyyyy.yyyyy,B,ssss.ss,hhh.hh,ddmmyy,mm.m,D,B*CS<CR><LF>$GPGGA,hhmmss.ss,llll.lllll,A,yyyyy.yyyyy,B,q,nn,hh.h,aaaaa.a,M,sss.s,M,a.a,aaaa*CS<CR><LF>$GPGSA,a,m,s1,s2,s3,s4,s5,s6,s7,s8,s9,s10,s11,s12,pp.p,hh.h,vv.v*CS<CR><LF>$GPVTG,ddd.dd,T,ddd.dd,M,ssss.ss,N,ssss.ss,K,a*CS<CR><LF>";
/* SPI2 transmit buffer in sys ram */
/* SPI1 receive buffer in sys ram */
uint16 mibSPI1_RX_Data[D_SIZE]= {0};
/* SPI2 receive buffer in sys ram */
g_dmaCTRL g_dmaCTRLPKT_RX; /* dma control packet configuration stack for receive */
g_dmaCTRL g_dmaCTRLPKT_TX; /* dma control packet configuration stack for transmit */
typedef enum dmaRequest
DMA_REQ0 = 0U, DMA_REQ1, DMA_REQ2, DMA_REQ3,
DMA_REQ4, DMA_REQ5, DMA_REQ6, DMA_REQ7,
DMA_REQ8, DMA_REQ9, DMA_REQ10, DMA_REQ11,
DMA_REQ12, DMA_REQ13, DMA_REQ14, DMA_REQ15,
DMA_REQ16, DMA_REQ17, DMA_REQ18, DMA_REQ19,
DMA_REQ20, DMA_REQ21, DMA_REQ22, DMA_REQ23,
DMA_REQ24, DMA_REQ25, DMA_REQ26, DMA_REQ27,
DMA_REQ28, DMA_REQ29, DMA_REQ30, DMA_REQ31,
DMA_REQ32, DMA_REQ33, DMA_REQ34, DMA_REQ35,
DMA_REQ36, DMA_REQ37, DMA_REQ38, DMA_REQ39,
DMA_REQ40, DMA_REQ41, DMA_REQ42, DMA_REQ43,
DMA_REQ44, DMA_REQ45, DMA_REQ46, DMA_REQ47
}dmaRequest_t;
unsigned MIBSPI_DMA_FLG;
/* USER CODE END */
int main(void)
/* USER CODE BEGIN (3) */
uint32 i;
_enable_interrupt_();
/* - initializing mibspi - enabling Transfer Group 0 , length 128 (halcogen file)*/
mibspiInit();
/* Enable TG 0,1,2,3 complete interrupt to INT 0 */
mibspiEnableGroupNotification(mibspiREG1,0,0);
// mibspiEnableLoopback(mibspiREG1,Digital_Lbk);
dmaDisable();
loadDataPattern1(D_SIZE, &mibSPI1_TX_Data[0]);
/* - configuring dma control packet for sending data to mibSPI3 tx buffer*/
dmaConfigCtrlRxPacket((uint32)&(mibspiRAM1->rx[0].data),(uint32)&(mibSPI1_RX_Data), E_COUNT, F_COUNT);
/* - configuring dma control packet for receiving data from mibSPI3 rx buffer*/
dmaConfigCtrlTxPacket((uint32)&(mibSPI1_TX_Data),(uint32)&(mibspiRAM1->tx[0].data), E_COUNT, F_COUNT);
/* - setting dma control packets for transmit */
dmaSetCtrlPacket(DMA_CH1, g_dmaCTRLPKT_TX);
/* - setting dma control packets for Receive */
dmaSetCtrlPacket(DMA_CH0, g_dmaCTRLPKT_RX);
/* DMA Request Sources: MIBSPI1[0] -> DMA request 1 */
dmaReqAssign(DMA_CH1, DMA_REQ9 ); /* Transmit data DMA channel enable. Request line=0*/
/* DMA Request Sources: MIBSPI1[1] -> DMA request 0 */
dmaReqAssign(DMA_CH0, DMA_REQ8 ); /* Receive data DMA channel enable. Request Line=1. */
/* - setting the dma channel to trigger on h/w request */
dmaSetChEnable(DMA_CH1, DMA_HW);
dmaSetChEnable(DMA_CH0, DMA_HW);
/* - configuring the mibspi dma , channel 0 , tx line -0 , rxline -1 */
/* - refer to the device data sheet dma request source for mibspi tx/rx */
mibspiDmaConfig(mibspiREG1, 0, 5, 4);
/* Enable Block Transfer Complete interrupt for the receive after transfer complete */
dmaEnableInterrupt(DMA_CH0, BTC); //MibSPI1 RX
/* enable DMA now to make sure it's ready to take requests */
dmaEnable();
// mibspiSetData(mibspiREG1, 0, &mibSPI1_TX_Data[0]);
// mibspiSetData(mibspiREG3, 0, &mibSPI3_TX_Data[0]);
for(i=0;i<=20;i++){printf("\n%dA",i);}
mibspiTransfer(mibspiREG1, 0);
while(MIBSPI_DMA_FLG == 0);
for(i=0;i<=D_SIZE;i++)
printf("\r\n%d mibSPI1_TX_Data: 0x%04x mibSPI1_RX_Data: 0x%04x ",i, mibSPI1_TX_Data[i], mibSPI1_RX_Data[i]);
while(1);
/* USER CODE END */
return 0;
/* USER CODE BEGIN (4) */
void dmaGroupANotification(dmaInterrupt_t inttype, uint32 channel)
MIBSPI_DMA_FLG = 1;
g_dmaCTRLPKT_TX.SADD = sadd; /* source address */
g_dmaCTRLPKT_TX.DADD = dadd; /* destination address */
g_dmaCTRLPKT_TX.CHCTRL = 0; /* channel control */
g_dmaCTRLPKT_TX.FRCNT = FrameCnt; /* frame count */
g_dmaCTRLPKT_TX.ELCNT = ElmntCnt; /* element count */
g_dmaCTRLPKT_TX.ELDOFFSET = 4; /* element destination offset */
g_dmaCTRLPKT_TX.ELSOFFSET = 0; /* element source offset */
g_dmaCTRLPKT_TX.FRDOFFSET = 0; /* frame destination offset */
g_dmaCTRLPKT_TX.FRSOFFSET = 0; /* frame destination offset */
g_dmaCTRLPKT_TX.PORTASGN = 4; /* port b */
g_dmaCTRLPKT_TX.RDSIZE = ACCESS_16_BIT; /* read size */
g_dmaCTRLPKT_TX.WRSIZE = ACCESS_16_BIT; /* write size */
g_dmaCTRLPKT_TX.TTYPE = FRAME_TRANSFER ; /* transfer type */
g_dmaCTRLPKT_TX.ADDMODERD = ADDR_INC1; /* address mode read */
g_dmaCTRLPKT_TX.ADDMODEWR = ADDR_OFFSET; /* address mode write */
g_dmaCTRLPKT_TX.AUTOINIT = AUTOINIT_ON; /* autoinit */
g_dmaCTRLPKT_RX.SADD = sadd; /* source address */
g_dmaCTRLPKT_RX.DADD = dadd; /* destination address */
g_dmaCTRLPKT_RX.CHCTRL = 0; /* channel control */
g_dmaCTRLPKT_RX.FRCNT = FrameCnt; /* frame count */
g_dmaCTRLPKT_RX.ELCNT = ElmntCnt; /* element count */
g_dmaCTRLPKT_RX.ELDOFFSET = 0; /* element destination offset */
g_dmaCTRLPKT_RX.ELSOFFSET = 4; /* element source offset */
g_dmaCTRLPKT_RX.FRDOFFSET = 0; /* frame destination offset */
g_dmaCTRLPKT_RX.FRSOFFSET = 0; /* frame destination offset */
g_dmaCTRLPKT_RX.PORTASGN = 4; /* port b */
g_dmaCTRLPKT_RX.RDSIZE = ACCESS_16_BIT; /* read size */
g_dmaCTRLPKT_RX.WRSIZE = ACCESS_16_BIT; /* write size */
g_dmaCTRLPKT_RX.TTYPE = FRAME_TRANSFER ; /* transfer type */
g_dmaCTRLPKT_RX.ADDMODERD = ADDR_OFFSET; /* address mode read */
g_dmaCTRLPKT_RX.ADDMODEWR = ADDR_INC1; /* address mode write */
g_dmaCTRLPKT_RX.AUTOINIT = AUTOINIT_ON; /* autoinit */
uint32 bufid = E_COUNT - 1; //number of buffers in TG0
/* setting transmit and receive channels */
mibspi->DMACTRL[channel] |= (rxchannel << 20) | (txchannel << 16);
if (F_COUNT > 1) {
mibspi->TGCTRL[channel] &= 0xBFFFFFFF; // Disable ONESHOT
} else {
mibspi->TGCTRL[channel] |= 0x40000000; // Enable ONESHOT
/* enabling transmit and receive dma */
mibspi->DMACTRL[channel] |= 0x8000C000;
/* setting Initial Count of DMA transfers and the buffer utilized for DMA transfer */
mibspi->DMACTRL[channel] |= (bufid<<24);
mibspi->DMACTRL[channel] |= ((F_COUNT - 1)<<8);
// /* setting Initial Count of DMA transfers and the buffer utilized for DMA transfer */
// mibspi->DMACTRL[channel] |= (0<<31);
// mibspi->DMACNTLEN = 0x1;
// mibspi->DMACOUNT[channel] = (F_COUNT - 1) << 16;
int i;
for(i=0;i<psize;i++)
pptr[i] = i;
int i;
int j = 0;
for(i=psize;i>0;i--)
pptr[j] = i;
j++;
/* USER CODE END */
* @date 11-Dec-2018
* @version 04.07.01
* are met:
* distribution.
/* USER CODE END */
/* Include Files */
#include "mibspi.h"
#include "stdio.h"
/* USER CODE END */
}dmaRequest_t;
/* USER CODE END */
int main(void)
uint32 i;
mibspiInit();
dmaDisable();
loadDataPattern2(D_SIZE, &mibSPI1_TX_Data[0]);
dmaEnable();
while(1);
/* USER CODE END */
return 0;
MIBSPI_DMA_FLG = 1;
if (F_COUNT > 1) {
} else {
int i;
pptr[i] = i;
int i;
int j = 0;
pptr[j] = i;
j++;
/* USER CODE END */
