Part Number: AM2434
How to configure to use MII on PRU_ICSSG?
There is no signal name in the SIGNAL NAME column in the "Table 6-1. Pin Attributes (ALV, ALX Packages)" on the datasheet that indicates MII on PRU_ICSSG.
The Mux Mode is 0 or 1 for MII on PRU_ICSSG in the SysConfig tool. It indicates the GPO or GPI on PRU_ICSSG in the SIGNAL NAME column in the "Table 6-1. Pin Attributes (ALV, ALX Packages)" on the datasheet.
The MII appears to be multiplexed with RGMII in "Figure 6-151. PRU_ICSSG0 External Interface I/Os" or "Figure 6-152. PRU_ICSSG1 External Interface I/Os" on the TRM.
Is the Mux Mode configuration in the SysConfig tool correct?
Daisuke
