Part Number: RM46L852
Other Parts Discussed in Thread: HALCOGEN
is there any example for FreeRTOS? I read about RM46 example_freeRTOSBlinky in the forum, but I can't found it.
Hi Armin,
You can easily create FreeRTOS Blinky example from HALCoGen
Go through the Help topics in HALCoGen
After that select "example_freeRTOSBlinky" in examples section as below
There you can see the step-by-step procedure to create LED blinky example using FreeRTOS.
Or else follow below PDF
Thanks & Regards,
Jagadish.
Hi Jagadish,
thank's, my fault was using HALCoGen 3 delivered with the CD ... with HALCoGen 4 I can found the examples :-)
Thanks a lot, regards
Armin
