Other Parts Discussed in Thread: TDA4VM
Hi mircea weingart,
Max96712 deserializer with TDA4VM EVM? How is this connected? Could you please help us understand?
From the above log, there are two errors,
1, It isn't able to configure sensor, can you please check if lock is detected between serializer and deserializer and deserializer is able to detect slave devices?
2, somehow setting of phy parameters is failing, can you please share the phy parameters that you are trying to set?
Brijesh
Can you please check Maxim for the first questions?
For the second question, can you please share parameters passes to SET_PHY_PARAMS control command?
Brijesh
Hi mircea weingart,
So are you using Linux CSIRX driver for configuring this camera? Because as far as i remember, Continental is using R5F for camera configuration.
Also could you please help me with the project for which you are using this camera? Because we have brought up this Maxim SERDES with sensor on Continental platform.
Brijesh
