Part Number: TMDS273GPEVM
Other Parts Discussed in Thread: AWR2243
Please tell me how to output 40MHz clock from EVM.
I want to supply a 40MHz square wave clock to an external AWR2243.
Best Regrads,
Hiroyuki Taguchi
Best Regrads,
Hiroyuki Taguchi
Hi Hiroyuki Taguchi,
Apologies for the delay.
PAD_DF(Ball number J1) of AM273, can be routed to have MCU_CLKOUT. This PAD_DF is connected to Connector J7, Pin 4 on the TMDS273GPEVM.
For 40MHz to be routed to this PAD_DF(Ball number J1), please configure the below registers.
NOTE: The RCM/TOPRCM registers might be multibit write.
Also, I see there is some inconsistency with the source clocks in TRM. We will update that.
Tejas Kulakarni
Hi Tejas,
Thank you fo your reply.
Please tell me one more thing.
Is the XTALCLK source signal output from MCU_CLKOUT?
Or maybe 40MHz divided to 40MHz after taking the PLL?
Hiroyuki
Yes, the XTALCLK is selected as source for MCU_CLKOUT when the MCUCLKOUT_CLK_SRC_SEL register with address 0x0214001C is set to 0x666.
To select source clock for MCU_CLKOUT as 40MHz (from XTALCLK), please set MCUCLKOUT_CLK_SRC_SEL register with address 0x0214001C to 0x666.
If you need to divide the selected source clock of MCU_CLKOUT, please look at programming the register MCUCLKOUT_DIV_VAL with address 0x02140048.
Tejas Kulakarni
