Part Number: LP-MSPM0L1306
Other Parts Discussed in Thread: CCSTUDIO
I tried install ARM GCC from App Center on CCS Version 12.0.0.00009, but I cannot install it.
It looks like App Center is unable to access the resource URL.
Please let me know if there is any way to solve this.
Error
Erro log
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2022-12-16 10:16:01.391 !MESSAGE Connection to http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/site.xml failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T13CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T13CertificateConsumer.onConsumeCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T13CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY com.ti.ccstudio.p2app 4 0 2022-12-16 10:16:01.886 !MESSAGE The installable unit com.ti.gcc.arm.win32.feature.group has not been found. !ENTRY com.ti.ccstudio.app.center 1 0 2022-12-16 10:16:01.896 !MESSAGE Failed to install the sele
