Part Number: MCU-PLUS-SDK-AM263X
Hi
I am checking epwm_hr_duty_cycle_am263x example code. I am able to change the duty cycle and frequency of the EPWM instance which is added in the example. But, When I add a new instance of EPWM in SysConfig it does not work (no output on pwm dedicated pins). The configuration of the new PWM instance is exactly same as the PWM which has been already added in the example but there is no output.
The above screenshots are the two configuration of the EPWM which are exactly same.
Would you please guide me if I am doing something wrong?
Best Regards
Saman
