TM4C129ENCPDT: Exit.c program for GCC lianaro 4.9.7 compiler for TI RTOS project not found "_lock.h" and "_unlock.h" files not found in gcc compiler
Part Number: TM4C129ENCPDT
Hi Everyone,
I am getting error during compiling TI RTOS project as "_lock.h" and  "_unlock.h" files not found in gcc compiler which is present in exit.c program here ill attach the code, _lock.h file is present in TI compiler and exit.c program is available in Ti arm compiler , where can i find the exit.c file in GCC compiler or similar program where i can replace exit.c in my code.
Thank you in advance.
Chiranth
exit,c file provided by TI arm compiler.
/*  EXIT.C v15.4.0I15142                                                    */
/* Copyright (c) 1995-2015 Texas Instruments Incorporated                   */
/* http://www.ti.com/                                                       */
/*  Redistribution and  use in source  and binary forms, with  or without   */
/*  modification,  are permitted provided  that the  following conditions   */
/*  are met:        */
/*     Redistributions  of source  code must  retain the  above copyright   */
/*     notice, this list of conditions and the following disclaimer.        */
/*     Redistributions in binary form  must reproduce the above copyright   */
/*     notice, this  list of conditions  and the following  disclaimer in   */
/*     the  documentation  and/or   other  materials  provided  with  the   */
/*     distribution.                                                        */
/*     Neither the  name of Texas Instruments Incorporated  nor the names   */
/*     of its  contributors may  be used to  endorse or  promote products   */
/*     derived  from   this  software  without   specific  prior  written   */
/*     permission.                                                          */
/*  THIS SOFTWARE  IS PROVIDED BY THE COPYRIGHT  HOLDERS AND CONTRIBUTORS   */
/*  "AS IS"  AND ANY  EXPRESS OR IMPLIED  WARRANTIES, INCLUDING,  BUT NOT   */
/*  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR   */
/*  A PARTICULAR PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL THE COPYRIGHT   */
/*  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,   */
/*  SPECIAL,  EXEMPLARY,  OR CONSEQUENTIAL  DAMAGES  (INCLUDING, BUT  NOT   */
/*  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,   */
/*  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY   */
/*  THEORY OF  LIABILITY, WHETHER IN CONTRACT, STRICT  LIABILITY, OR TORT   */
/*  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE   */
/*  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.    */
#include <stdlib.h>
#include <_lock.h>
void                     (*__TI_cleanup_ptr)(void) = NULL;
void   _DATA_ACCESS      (*__TI_dtors_ptr)(int)    = NULL;
void	JumpToBootLoader(void);
/* LOADER_EXIT -							    */
/* SET C$$EXIT LABEL SO THE DEBUGGER KNOWS WHEN THE C++ PROGRAM HAS	    */
/* COMPLETED.  THIS CAN BE REMOVED IF THE DEBUGGER IS NOT USED.		    */
static void loader_exit(void)
#if defined(EMBED_CIO_BP)
   __asm("         .global C$$EXITE");
#if defined(__32bis__)
   __asm("C$$EXITE:.word 0xDEFED0FE");
#else
   __asm("	 .align  4");
#if defined(__big_endian__)
   __asm("C$$EXITE:.half 0xDEFE");
#else
   __asm("C$$EXITE:.half 0xD0FE");
#endif /* __big_endian__ */
#endif /* __32bis__      */
#else  /* !EMBED_CIO_BP */
   __asm("C$$EXITE: nop");
#endif
/* EXIT() - NORMAL PROGRAM TERMINATION.                                     */
extern void exit(int status)
   /* MUST LOCK WHEN ACCESSING GLOBALS, like __TI_dtors_ptr,            */
   /* __TI_cleanup_ptr                                                  */
   _lock();
   /* BOTH ATEXIT FUNCTIONS AND STATIC OBJECT DESTRUCTORS ARE           */
   /* REGISTERED IN A LINK LIST TO BE PROCESSED BY THE FUNCTION POINTED */
   /* TO BY __TI_dtors_ptr.  PROCESS THEM NOW.                          */
   if (__TI_dtors_ptr)  (*__TI_dtors_ptr)(status);
#if defined(_C_IN_NS)
   /* _C_IN_NS IS A FLAG WE SET ONLY IN DINKUMWARE HEADERS. SO US IT TO */
   /* TELL IF IT IS IN DINKUMWARE.                                      */
   /* FOR DINKUMWARE LIBRARY, CALL CLOSEALL() TO CLOSE ALL IO STREAMS.  */
   /* CLOSEALL() is a DINKUMWARE FUNCTION DEFINED IN FCLOSE.C TO CLOSE  */
   /* ALL OPENED IOSTREAMS.                                             */
   closeall();
#else
   /* IF FILES ARE POSSIBLY OPEN, __TI_cleanup_ptr() WILL BE SETUP TO   */
   /* CLOSE THEM.                                                       */
   if (__TI_cleanup_ptr)  (*__TI_cleanup_ptr)();
#endif
   _unlock();
   abort();
/* ABORT - ABNORMAL PROGRAM TERMINATION.  CURRENTLY JUST HALTS EXECUTION.   */
void abort(void)
	JumpToBootLoader();
    loader_exit();
    for (;;);   /* SPINS FOREVER */
_lock.h file called by exit.c file
/*  _lock.h v5.2.9                                                           */
/* Copyright (c) 2000-2017 Texas Instruments Incorporated                    */
/*  are met:        */
/*     distribution.                                                         */
/*     permission.                                                           */
#ifndef __LOCK_H
#define __LOCK_H
#include <linkage.h>
#ifdef __cplusplus
extern "C" {
#endif
#pragma diag_push
/* _nop(), _lock(), and _unlock() all accept zero or more optional arguments,
   which must remain as empty rather than (void) parameter lists to avoid
   breaking the API */
#pragma CHECK_MISRA("-16.5")
_CODE_ACCESS void _nop();
extern _DATA_ACCESS void (  *_lock)();
extern _DATA_ACCESS void (*_unlock)();
_CODE_ACCESS void _register_lock  (void (  *lock)());
_CODE_ACCESS void _register_unlock(void (*unlock)());
#pragma diag_pop
#define SYSTEM_WIDE_LOCK_REGISTERED	(_lock != _nop)
#define SYSTEM_WIDE_UNLOCK_REGISTERED	(_unlock != _nop)
#ifdef __cplusplus
} /* extern "C" */
#endif
#endif /* __LOCK_H */
linkage.h file called by _lock.h file
/* linkage.h   v5.2.9                                                        */
/* Copyright (c) 1998-2017 Texas Instruments Incorporated                    */
/*  are met:        */
/*     distribution.                                                         */
/*     permission.                                                           */
#ifndef _LINKAGE
#define _LINKAGE
#pragma diag_push
#pragma CHECK_MISRA("-19.4") /* macros required for implementation */
/* No modifiers are needed to access code or data */
#define _CODE_ACCESS
#define _DATA_ACCESS
#define _DATA_ACCESS_NEAR
/* Define _IDECL ==> how inline functions are declared                      */
#ifdef _INLINE
#define _IDECL static __inline
#define _IDEFN static __inline
#define __INLINE static __inline
#else
#define _IDECL extern _CODE_ACCESS
#define _IDEFN _CODE_ACCESS
#define __INLINE __EXTERN
#endif
#pragma diag_pop
#endif /* ifndef _LINKAGE */
