Part Number: TM4C129ENCZAD
Other Parts Discussed in Thread: AWR1843BOOST, TM4C1294NCPDT, TM4C129ENCPDT
XDS110 was written to TM4C129ENCZAD.
TM4C129ENCZAD was not supported,
C:\ti\ccs1120\ccs\ccs_base\common\uscif\xds110 bootloader and firmware in this hierarchy were written with the attached command.
Therefore, it can be written and recognized by the device manager, but is it okay to think that there is no problem in operation?
Implemented in AWR1843BOOST as an example
Can I expect the same performance as TM4C1294NCPDT?
Also, are there any problems with the TM4C129ENCZAD pin connections and MCU?
Microsoft Windows [Version 10.0.19044.1706] (c) Microsoft Corporation. All rights reserved. C:\Users\kashidashi.24>cd C:\ti\ccs1120\ccs\ccs_base\common\uscif\xds110 C:\ti\ccs1120\ccs\ccs_base\common\uscif\xds110>xdsdfu.exe -e USB Device Firmware Upgrade Utility Copyright (c) 2008-2019 Texas Instruments Incorporated. All rights reserved. Scanning USB buses for supported XDS110 devices... <<<< Device 0 >>>> VID: 0x1cbe PID: 0x00ff Device Name: Tiva Device Firmware Update Manufacturer: Texas Instruments Incorporated Serial Num: 00000000 Mode: DFU Found 1 device. C:\ti\ccs1120\ccs\ccs_base\common\uscif\xds110>xdsdfu.exe -b boot_loader.bin USB Device Firmware Upgrade Utility Copyright (c) 2008-2019 Texas Instruments Incorporated. All rights reserved. Replacing the bootloader may render the XDS110 unusable. Do you want to continue (Y/N) ? Y Scanning USB buses for supported XDS110 devices... Downloading boot_loader.bin to device... C:\ti\ccs1120\ccs\ccs_base\common\uscif\xds110>xdsdfu.exe -e USB Device Firmware Upgrade Utility Copyright (c) 2008-2019 Texas Instruments Incorporated. All rights reserved. Scanning USB buses for supported XDS110 devices... <<<< Device 0 >>>> VID: 0x1cbe PID: 0x00ff Device Name: Tiva Device Firmware Update Manufacturer: Texas Instruments Incorporated Serial Num: 00000000 Mode: DFU Found 1 device. C:\ti\ccs1120\ccs\ccs_base\common\uscif\xds110>xdsdfu.exe -f firmware_3.0.0.20.bin -r USB Device Firmware Upgrade Utility Copyright (c) 2008-2019 Texas Instruments Incorporated. All rights reserved. Scanning USB buses for supported XDS110 devices... Downloading firmware_3.0.0.20.bin to device... C:\ti\ccs1120\ccs\ccs_base\common\uscif\xds110>xdsdfu.exe -e USB Device Firmware Upgrade Utility Copyright (c) 2008-2019 Texas Instruments Incorporated. All rights reserved. Scanning USB buses for supported XDS110 devices... <<<< Device 0 >>>> VID: 0x0451 PID: 0xbef3 Device Name: XDS110 Embed with CMSIS-DAP Version: 3.0.0.20 Manufacturer: Texas Instruments Serial Num: 00000000 Mode: Runtime Configuration: Standard Found 1 device. C:\ti\ccs1120\ccs\ccs_base\common\uscif\xds110>xdsdfu.exe -m
