Part Number: EK-TM4C1294XL
I have noticed a strange issue when trying to use sendto() to send UDP packets. The issue appears when I try to send periodically too soon after initialization. Symptoms:
- sendto does not work and reports ENOBUFS for 15-30 seconds, and eventually recovers and starts sending at the correct frequency. (Watching network traffic in Wireshark and SocketTest)
- if I add a delay before starting the periodic sends, I don't see the issue at all, periodic sends just work as soon as they start. (sendto always returns the correct number of bytes successfully sent as opposed to -1 when it's not working and traffic is visible in wireshark and sockettest)
Does anyone know what might cause this?
Tools:
TM4C1294 Dev Kit
TI-RTOS TIVAC 2.16
NDK 2.25
Program:
A modified version of enet_udpecho_client_tirtos using clock module to send periodically (order of 100-200 ms) instead of echo.
Also not entirely sure if this is the right forum, let me know if it should be moved.
