Part Number: TMS570LC4357
Can someone point me in the direction to Implementing Z Modem Bootloader for TMS570LC4357.
Is there any Code or Library available?
I could find the Bootloader for Y Modem for TMS570LC4357.
Sakti
Sakti
Hi Sakti,
We provide example code for uart bootloader which uses ymodem.
TMS570 Hercules MCU Bootloader - Texas Instruments Wiki (ti.com)
Thanks & regards,
Jagadish.
Hello Jagadish,
Thank You for the reply. I can use this Bootloader to Flash Application.
I am looking for z-modem Bootloader or something similar as I am looking to Implement Bootloader where UART Data Receiving can be done in an Periodic manner and not using an endless while loop. Please let me know If you can help me here.
Thanks and Regards,
Sakti
Hi Sakti,
The below thread contains the UART bootloader code, can you please check whether the code meets all your requirements.
Thanks & regards,
Jagadish.
Hello Jagadish,
(7) TMS570LC4357: Bootloader example code - Arm-based microcontrollers forum - Arm-based microcontrollers - TI E2E support forums
I am already successful in flashing Application using ymodem as per the Bootloader example code given by you.
The next step for me is to try to flash the Application using Periodic Tasks.
I can see that ymodem does not have capability to receive the Data packets in Periodic task but does it in a while loop as shown below.
I wish to flash the Application in a periodic task (500ms) and was looking for a protocol that does so. It looks like it may be possible in Z-modem. Therefore I am looking for z-modem based Bootloader or something similar. Please let me know of any protocol or method where I can achieve it.
Thanks and Regards,
Sakti
Hi Sakti,
Apologies for the delay, discussing with internal team and will provide an update as soon as possible.
Thanks & regards,
Jagadish.
Hi Sakti,
Don't get feedback from internal team yet, i will again remaind them for reply.
Thanks & regards,
Jagadish.
Hi Sakti,
Sorry for delay, i am on vacation for last week.
I didn't get feedback from internal team yet, i again sent a remainder to them for answer.
Thanks & regards,
Jagadish.
Hi Sakti,
The internal team confirmed that we don't have any Z-modem related bootloaders or method to achieve it.
Thanks & regards,
Jagadish.
