Part Number: AM2732
Would you pls help on below questions about QSPI flash support on AM2732?
1. Is QE bit set MUST for the qspi flash? If not, will the ROM code set the QE bit? If yes, does the ROM default QE register is at bit 6 of Status Register 1?
2. Would you pls kindly advise the detail flow of the boot from QSPI? Such as send SFDP command first, etc.
Chris
