Part Number: TM4C129ENCPDT
Other Parts Discussed in Thread: CC3100,
Hi everyone,
i am facing Unresolved symbols during linking stage while executing Host Programming for CC3100 , can you check what i am missing ,
Thanks in advance
Console output:
**** Build of configuration Debug for project host_test **** "C:\\ti\\ccs\\utils\\bin\\gmake" -k -j 2 all -O Building file: "../tm4c129encpdt_startup_ccs.c" Invoking: Arm Compiler "C:/ti/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="C:/Users/chira/workspace_v12/host_test" --include_path="C:/ti/CC3100SDK_1.3.0/cc3100-sdk/simplelink/include" --include_path="C:/ti/CC3100SDK_1.3.0/cc3100-sdk/simplelink" --include_path="C:/ti/CC3100SDK_1.3.0/cc3100-sdk/platform/tiva-c-connected-launchpad" --include_path="C:/ti/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" --define=ccs="ccs" --define=PART_TM4C129ENCPDT -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="tm4c129encpdt_startup_ccs.d_raw" "../tm4c129encpdt_startup_ccs.c" Finished building: "../tm4c129encpdt_startup_ccs.c" Building file: "../main.c" Invoking: Arm Compiler "C:/ti/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="C:/Users/chira/workspace_v12/host_test" --include_path="C:/ti/CC3100SDK_1.3.0/cc3100-sdk/simplelink/include" --include_path="C:/ti/CC3100SDK_1.3.0/cc3100-sdk/simplelink" --include_path="C:/ti/CC3100SDK_1.3.0/cc3100-sdk/platform/tiva-c-connected-launchpad" --include_path="C:/ti/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" --define=ccs="ccs" --define=PART_TM4C129ENCPDT -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="main.d_raw" "../main.c" "../main.c", line 216: warning #225-D: function "initLEDs" declared implicitly Finished building: "../main.c" Building target: "host_test.out" Invoking: Arm Linker "C:/ti/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --define=ccs="ccs" --define=PART_TM4C129ENCPDT -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi -z -m"host_test.map" --heap_size=0 --stack_size=512 -i"C:/ti/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/lib" -i"C:/ti/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" --reread_libs --diag_wrap=off --display_error_number --warn_sections --xml_link_info="host_test_linkInfo.xml" --rom_model -o "host_test.out" "./main.obj" "./tm4c129encpdt_startup_ccs.obj" "../tm4c129encpdt.cmd" -llibc.a <Linking> undefined first referenced symbol in file --------- ---------------- CLI_Configure ./main.obj CLI_Write ./main.obj _sl_GetCreateFsMode ./main.obj initClk ./main.obj initLEDs ./main.obj sl_DevGet ./main.obj sl_FsClose ./main.obj sl_FsOpen ./main.obj sl_FsWrite ./main.obj sl_Start ./main.obj sl_Stop ./main.obj stopWDT ./main.obj error #10234-D: unresolved symbols remain error #10010: errors encountered during linking; "host_test.out" not built >> Compilation failure makefile:136: recipe for target 'host_test.out' failed makefile:132: recipe for target 'all' failed gmake[1]: *** [host_test.out] Error 1 gmake: *** [all] Error 2 **** Build Finished ****
here i have attached the project
https://drive.google.com/file/d/1-SBy3ZWX205M_MnTwN1ZzPBzxzZ3m6Hf/view?usp=share_link
thanks in advance
Chiranth
