Part Number: TM4C123GH6PM
Could it be possible to generate pwm such that as the duty cycle increases, the frequency increases as well?
What would be the strategies for achieving a variable frequency pwm driver?
a. can we set PWMGenPeriodSet dynamically, each time we set a pwm duty cycle?
b. how can we use different PWM generators running at different frequencies, and generate a PWM signal from the same pin, depending on the duty cycle generator with low or high frequency is used.
Can
