Part Number: TM4C1294KCPDT
The yellow part of the data sheet below says "Active", but which is output, High or Low?
Since TTL is indicated in the datasheet, is it correct to assume that LED0~2 port outputs are generally Active Low?
Eevee
Eevee
By default, 'Active' means it will be active high. You can change to active low by configuring the POL bit to 1 for the EMACCC register. Please see below.
