Part Number: TMS470MF03107
Other Parts Discussed in Thread: HALCOGEN
Could you please review the schematic design?
We normally do not review customer's schematic as we do not understand customer's complete systems. With that said, from a high level I do not spot anything that is wrong in the schematic.
Can you see what's wrong with the program?
/** @file rti.c
* @brief RTI Driver Source File
* @date 11-Dec-2018
* @version 04.07.01
* This file contains:
* - API Functions
* - Interrupt Handlers
* which are relevant for the RTI driver.
* Copyright (C) 2009-2018 Texas Instruments Incorporated - www.ti.com
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
/* USER CODE END */
/* Include Files */
#include "rti.h"
/* USER CODE BEGIN (1) */
extern void isr_timer_1ms(void);
extern void PIT_1msHandle(void);
/* USER CODE END */
/** @fn void rtiInit(void)
* @brief Initializes RTI Driver
* This function initializes the RTI driver.
/* USER CODE BEGIN (2) */
/* USER CODE END */
void rtiInit(void)
/* USER CODE BEGIN (3) */
/* USER CODE END */
/** @b Initialize @b RTI1: */
/** - Setup NTU source, debug options and disable both counter blocks */
rtiREG1->GCTRL = (0U << 16U) | 0x00000000U;
/** - Setup timebase for free running counter 0 */
rtiREG1->TBCTRL = 0x00000000U;
/** - Enable/Disable capture event sources for both counter blocks */
rtiREG1->CAPCTRL = 0U | 0U;
/** - Setup input source compare 0-3 */
rtiREG1->COMPCTRL = 0x00001000U | 0x00000100U | 0x00000000U | 0x00000000U;
/** - Reset up counter 0 */
rtiREG1->CNT[0U].UCx = 0x00000000U;
/** - Reset free running counter 0 */
rtiREG1->CNT[0U].FRCx = 0x00000000U;
/** - Setup up counter 0 compare value
* - 0x00000000: Divide by 2^32
* - 0x00000001-0xFFFFFFFF: Divide by (CPUC0 + 1)
rtiREG1->CNT[0U].CPUCx = 7U;
/** - Reset up counter 1 */
rtiREG1->CNT[1U].UCx = 0x00000000U;
/** - Reset free running counter 1 */
rtiREG1->CNT[1U].FRCx = 0x00000000U;
/** - Setup up counter 1 compare value
* - 0x00000001-0xFFFFFFFF: Divide by (CPUC1 + 1)
rtiREG1->CNT[1U].CPUCx = 7U;
/** - Setup compare 0 value. This value is compared with selected free running counter. */
rtiREG1->CMP[0U].COMPx = 10000U;
/** - Setup update compare 0 value. This value is added to the compare 0 value on each compare match. */
rtiREG1->CMP[0U].UDCPx = 10000U;
/** - Setup compare 1 value. This value is compared with selected free running counter. */
rtiREG1->CMP[1U].COMPx = 50000U;
/** - Setup update compare 1 value. This value is added to the compare 1 value on each compare match. */
rtiREG1->CMP[1U].UDCPx = 50000U;
/** - Setup compare 2 value. This value is compared with selected free running counter. */
rtiREG1->CMP[2U].COMPx = 80000U;
/** - Setup update compare 2 value. This value is added to the compare 2 value on each compare match. */
rtiREG1->CMP[2U].UDCPx = 80000U;
/** - Setup compare 3 value. This value is compared with selected free running counter. */
rtiREG1->CMP[3U].COMPx = 100000U;
/** - Setup update compare 3 value. This value is added to the compare 3 value on each compare match. */
rtiREG1->CMP[3U].UDCPx = 100000U;
/** - Clear all pending interrupts */
rtiREG1->INTFLAG = 0x0007000FU;
/** - Disable all interrupts */
rtiREG1->CLEARINT = 0x00070F0FU;
/** - Load DWD Preload Value*/
rtiREG1->DWDPRLD = 0x00000001U;
/** @note This function has to be called before the driver can be used.\n
* This function has to be executed in privileged mode.\n
* This function does not start the counters.
/* USER CODE BEGIN (4) */
/* USER CODE END */
/* USER CODE BEGIN (5) */
/* USER CODE END */
/** @fn void rtiStartCounter(uint32 counter)
* @brief Starts RTI Counter block
* @param[in] counter Select counter block to be started:
* - rtiCOUNTER_BLOCK0: RTI counter block 0 will be started
* - rtiCOUNTER_BLOCK1: RTI counter block 1 will be started
* This function starts selected counter block of the selected RTI module.
/* USER CODE BEGIN (6) */
/* USER CODE END */
/* USER CODE BEGIN (7) */
/* USER CODE END */
rtiREG1->GCTRL |= (1U << (counter & 3U));
/** @note The function rtiInit has to be called before this function can be used.\n
/* USER CODE BEGIN (8) */
/* USER CODE END */
/* USER CODE BEGIN (9) */
/* USER CODE END */
/** @fn void rtiStopCounter(uint32 counter)
* @brief Stops RTI Counter block
* @param[in] counter Select counter to be stopped:
* - rtiCOUNTER_BLOCK0: RTI counter block 0 will be stopped
* - rtiCOUNTER_BLOCK1: RTI counter block 1 will be stopped
* This function stops selected counter block of the selected RTI module.
/* USER CODE BEGIN (10) */
/* USER CODE END */
/* USER CODE BEGIN (11) */
/* USER CODE END */
rtiREG1->GCTRL &= ~(1U << (counter & 3U));
/* USER CODE BEGIN (12) */
/* USER CODE END */
/* USER CODE BEGIN (13) */
/* USER CODE END */
/** @fn uint32 rtiResetCounter(uint32 counter)
* @brief Reset RTI Counter block
* @param[in] counter Select counter block to be reset:
* - rtiCOUNTER_BLOCK0: RTI counter block 0 will be reset
* - rtiCOUNTER_BLOCK1: RTI counter block 1 will be reset
* @return The function will return:
* - 0: When the counter reset wasn't successful
* - 1: When the counter reset was successful
* This function resets selected counter block of the selected RTI module.
/* USER CODE BEGIN (14) */
/* USER CODE END */
uint32 success = 0U;
/* USER CODE BEGIN (15) */
/* USER CODE END */
if ((!(rtiREG1->GCTRL & (1U << (counter & 3U)))) != 0U)
rtiREG1->CNT[counter].UCx = 0x00000000U;
rtiREG1->CNT[counter].FRCx = 0x00000000U;
success = 1U;
* The selected counter block has to be stopped before it can reset.
/* USER CODE BEGIN (16) */
/* USER CODE END */
return success;
/* USER CODE BEGIN (17) */
/* USER CODE END */
/** @fn void rtiSetPeriod(uint32 compare, uint32 period)
* @brief Set new period of RTI compare
* @param[in] compare Select compare to change period:
* - rtiCOMPARE0: RTI compare 0 will change the period
* - rtiCOMPARE1: RTI compare 1 will change the period
* - rtiCOMPARE2: RTI compare 2 will change the period
* - rtiCOMPARE3: RTI compare 3 will change the period
* @param[in] period new period in [ticks - 1]:
* - 0x00000000: Divide by 1
* - n: Divide by n + 1
* This function will change the period of the selected compare.
/* USER CODE BEGIN (18) */
/* USER CODE END */
/* USER CODE BEGIN (19) */
/* USER CODE END */
rtiREG1->CMP[compare].UDCPx = period;
* When the corresponding counter block is not stopped,\n
* the period will change on the next compare match of the old period.
/* USER CODE BEGIN (20) */
/* USER CODE END */
/* USER CODE BEGIN (21) */
/* USER CODE END */
/** @fn uint32 rtiGetPeriod(uint32 compare)
* @brief Get current period of RTI compare
* @param[in] compare Select compare to return the current period:
* - rtiCOMPARE0: RTI compare 0 will return the current period
* - rtiCOMPARE1: RTI compare 1 will return the current period
* - rtiCOMPARE2: RTI compare 2 will return the current period
* - rtiCOMPARE3: RTI compare 3 will return the current period
* @return Current period of selected compare in [ticks - 1]:
* This function will return the period of the selected compare.
/* USER CODE BEGIN (22) */
/* USER CODE END */
uint32 period;
/* USER CODE BEGIN (23) */
/* USER CODE END */
period = rtiREG1->CMP[compare].UDCPx;
/* USER CODE BEGIN (24) */
/* USER CODE END */
return period;
/* USER CODE BEGIN (25) */
/* USER CODE END */
/** @fn uint32 rtiGetCurrentTick(uint32 compare)
* @brief Get current tick of RTI compare
* @param[in] compare Select compare to return the current tick:
* - rtiCOMPARE0: RTI compare 0 will return the current tick
* - rtiCOMPARE1: RTI compare 1 will return the current tick
* - rtiCOMPARE2: RTI compare 2 will return the current tick
* - rtiCOMPARE3: RTI compare 3 will return the current tick
* @return Current tick of selected compare
* This function will return the current of the selected compare.
/* USER CODE BEGIN (26) */
/* USER CODE END */
uint32 tick;
uint32 counter = ((rtiREG1->COMPCTRL & (1U << (compare << 2U))) !=0U ) ? 1U : 0U;
/* USER CODE BEGIN (27) */
/* USER CODE END */
tick = rtiREG1->CNT[counter].FRCx - (rtiREG1->CMP[compare].COMPx - rtiREG1->CMP[compare].UDCPx);
/* USER CODE BEGIN (28) */
/* USER CODE END */
return tick;
/* USER CODE BEGIN (29) */
/* USER CODE END */
/** @fn void rtiEnableDWD(void)
* @brief Enable DWD with expiration time set in Halcogen GUI
* This function will enable DWD and set the expiration time of DWD counter.
/* USER CODE BEGIN (30) */
/* USER CODE END */
/* USER CODE BEGIN (31) */
/* USER CODE END */
rtiREG1->DWDCTRL = 0xA98559DAU;
rtiREG1->WDKEY = 0xE51AU;
rtiREG1->WDKEY = 0xA35CU;
/* USER CODE BEGIN (32) */
/* USER CODE END */
/** @fn void rtiSetDWDExpirationTime(uint32 exp_time)
* @param[in] exp_time:
* This function will change the expiration time of DWD counter.
/* USER CODE BEGIN (33) */
/* USER CODE END */
/* USER CODE BEGIN (34) */
/* USER CODE END */
rtiREG1->DWDPRLD = exp_time;
/* USER CODE BEGIN (35) */
/* USER CODE END */
/* USER CODE BEGIN (36) */
/* USER CODE END */
/** @fn void rtiReloadDWD(void)
* @brief Reloads the DWD down counter with Preload value
* This function will reload the 25-bit DWD down counter with the left justified
* 12-bit preload value stored in RTIDWDPRLD by writing key sequence to the
* TIWDKEY register (0xE51A followed by 0xA35C),
/* USER CODE BEGIN (37) */
/* USER CODE END */
/* USER CODE BEGIN (38) */
/* USER CODE END */
/* USER CODE BEGIN (39) */
/* USER CODE END */
/** @fn void rtiEnableNotification(uint32 notification)
* @brief Enable notification of RTI module
* @param[in] notification Select notification of RTI module:
* - rtiNOTIFICATION_COMPARE0: RTI compare 0 notification
* - rtiNOTIFICATION_COMPARE1: RTI compare 1 notification
* - rtiNOTIFICATION_COMPARE2: RTI compare 2 notification
* - rtiNOTIFICATION_COMPARE3: RTI compare 3 notification
* - rtiNOTIFICATION_TIMEBASE: RTI Timebase notification
* - rtiNOTIFICATION_COUNTER0: RTI counter 0 overflow notification
* - rtiNOTIFICATION_COUNTER1: RTI counter 1 overflow notification
* This function will enable the selected notification of a RTI module.
* It is possible to enable multiple notifications masked.
/* USER CODE BEGIN (40) */
/* USER CODE END */
/* USER CODE BEGIN (41) */
/* USER CODE END */
rtiREG1->INTFLAG = notification;
rtiREG1->SETINT = notification;
/* USER CODE BEGIN (42) */
/* USER CODE END */
/* USER CODE BEGIN (43) */
/* USER CODE END */
/** @fn void rtiDisableNotification(uint32 notification)
* @brief Disable notification of RTI module
* This function will disable the selected notification of a RTI module.
* It is possible to disable multiple notifications masked.
/* USER CODE BEGIN (44) */
/* USER CODE END */
/* USER CODE BEGIN (45) */
/* USER CODE END */
rtiREG1->CLEARINT = notification;
/* USER CODE BEGIN (46) */
/* USER CODE END */
/* USER CODE BEGIN (47) */
/* USER CODE END */
/** @fn void rtiCompare0Interrupt(void)
* @brief RTI1 Compare 0 Interrupt Handler
* RTI1 Compare 0 interrupt handler
/* USER CODE BEGIN (48) */
/* USER CODE END */
#pragma INTERRUPT(rtiCompare0Interrupt)
/* USER CODE BEGIN (49) */
isr_timer_1ms();
PIT_1msHandle();
/* USER CODE END */
rtiREG1->INTFLAG = 1U;
rtiNotification(rtiNOTIFICATION_COMPARE0);
/* USER CODE BEGIN (50) */
/* USER CODE END */
/* USER CODE BEGIN (51) */
/* USER CODE END */
/** @fn void rtiCompare1Interrupt(void)
* @brief RTI1 Compare 1 Interrupt Handler
* RTI1 Compare 1 interrupt handler
/* USER CODE BEGIN (52) */
/* USER CODE END */
#pragma INTERRUPT(rtiCompare1Interrupt)
/* USER CODE BEGIN (53) */
/* USER CODE END */
rtiREG1->INTFLAG = 2U;
rtiNotification(rtiNOTIFICATION_COMPARE1);
/* USER CODE BEGIN (54) */
/* USER CODE END */
/* USER CODE BEGIN (55) */
/* USER CODE END */
/** @fn void rtiCompare2Interrupt(void)
* @brief RTI1 Compare 2 Interrupt Handler
* RTI1 Compare 2 interrupt handler
/* USER CODE BEGIN (56) */
/* USER CODE END */
#pragma INTERRUPT(rtiCompare2Interrupt)
/* USER CODE BEGIN (57) */
/* USER CODE END */
rtiREG1->INTFLAG = 4U;
rtiNotification(rtiNOTIFICATION_COMPARE2);
/* USER CODE BEGIN (58) */
/* USER CODE END */
/* USER CODE BEGIN (59) */
/* USER CODE END */
/** @fn void rtiCompare3Interrupt(void)
* @brief RTI1 Compare 3 Interrupt Handler
* RTI1 Compare 3 interrupt handler
/* USER CODE BEGIN (60) */
/* USER CODE END */
#pragma INTERRUPT(rtiCompare3Interrupt)
/* USER CODE BEGIN (61) */
/* USER CODE END */
rtiREG1->INTFLAG = 8U;
rtiNotification(rtiNOTIFICATION_COMPARE3);
/* USER CODE BEGIN (62) */
/* USER CODE END */
/* USER CODE BEGIN (63) */
/* USER CODE END */
/** @fn void rtiOverflow0Interrupt(void)
* @brief RTI1 Counter 0 overflow Interrupt Handler
* RTI1 counter 0 overflow interrupt handler
/* USER CODE BEGIN (64) */
/* USER CODE END */
#pragma INTERRUPT(rtiOverflow0Interrupt)
/* USER CODE BEGIN (65) */
/* USER CODE END */
rtiREG1->INTFLAG = 0x20000U;
rtiNotification(rtiNOTIFICATION_COUNTER0);
/* USER CODE BEGIN (66) */
/* USER CODE END */
/* USER CODE BEGIN (67) */
/* USER CODE END */
/** @fn void rtiOverflow1Interrupt(void)
* @brief RTI1 Counter 1 overflow Interrupt Handler
* RTI1 counter 1 overflow interrupt handler
/* USER CODE BEGIN (68) */
/* USER CODE END */
#pragma INTERRUPT(rtiOverflow1Interrupt)
/* USER CODE BEGIN (69) */
/* USER CODE END */
rtiREG1->INTFLAG = 0x40000U;
rtiNotification(rtiNOTIFICATION_COUNTER1);
/* USER CODE BEGIN (70) */
/* USER CODE END */
/* USER CODE BEGIN (71) */
/* USER CODE END */
What is wrong with rti.h? This is a HalcoGen generated header file? I don't see anything wrong. If RTI is not working then please elaborate what is not working.
