Part Number: MSPM0L1304
Hi Team,
Can MSPM0L work with 1MHz by external oscillator?
Yuta Ishii
Hi Team,
Yuta Ishii
Hi Yuta,
No, the MSPM0L1xxx devices do not have an input for an external oscillator.
Brandon Fisher
Hi Yuta,
The SYSOSC Frequency and User Trims section (Section 2.3.1.2.2.) of the TRM describes the potential frequencies for SYSOSC as 32MHz, 4MHz (Factory Trimmed), or 24Mhz and 16MHz (User trimmed).
The SYSOSC frequency is different than the MCLK frequency however. You can run SYSOSC at 4MHZ and set MCLK from 4MHz to 250KHz using the MDIV setting.
If running the CPU at 1MHz is desired, use SYSOC at 4MHZ, and set MDIV to 3.
Brandon Fisher
