Part Number: TMDSCNCD263
Other Parts Discussed in Thread: AM2634
Hello Team,
Posting on behalf of my customer:
Renan
Hello Team,
Hi Renan,
We do not have ICSS EMAC available for am263x SDK. Could you please tell me more about your use case. Also what interface is the automotive ethernet using?(MII/RGMII/RMI)
Hello Nilabh,
Good day please see the response from my customer:
In my use case, I require the establishment of a connection between the board and two different devices using two distinct physical ports from the board. Additionally, I need to assign a unique static IP for each port. However, I faced difficulty in achieving this using the cpsw as I was unable to enable both physical ports simultaneously without mirroring.
Therefore, I am unsure if it is possible to have two IP addresses to enable two physical ports separately.
The automotive ethernet is using RGMII.
Renan
Thanks Renan,
Please follow this for assigning static ip address on both ports: https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1222677/am2434-cpsw-dual-mac-mode
Yes RGMII is supported. Above should resolve your issue. Please let me know if you need any other help.
