Part Number: MSPM0G3507
Hi team,
Use the latest version of the G3507 monolithic machine.
Purpose: After the LFCLK clock source LFXT has been de-asserted, have the MCU reset switch to LFOSC, and then switch to LFXT after the LFXT returns to normal. Some of the code are as below:
Test LFXT failed to enter good interrupt after good started, it did not enter NMI interrupt test (turned on) when LFXT failed, but MCU reset (why after LFXT failed, Reset without interrupt?) .
How to switch to LFOSC after LFXT failure (reset only once is also OK? And how can the LFXT switch back normally when it returns to normal? Is there any scheme and routine code available?
Could you help check this case? Thanks.
Cherry
