Part Number: AM2634-Q1
Hi TI Expert,
How to configure the core clock frequency to a desired frequency (for example 300MHz)?
Thanks in advance!
Hi Sue,
It is not straight forward and at the moment we haven't provided the User configuration of the Master PLL and clock tree to the User. We are planning to integratie this feature in the Sysconfig in the near future.
However, I can give you the changes you can make in the GEL file (Not in the SBL) if you wish to still configure it.
G Kowshik
Hi Kowshik,
Thanks for your response.
Yes, please share the steps to configure it in GEL file.
Also, could you please share the steps and API to use if I were to configure it in code? or share the link to the documentation if available?
Thank You!
Please change this line in the AM263_PLL.gel under the path /home/kowshik/ti/ccs1210/ccs/ccs_base/emulation/gel/AM263x/AM263_PLL/AM263_PLL.gel
Unfortunately we do not have that information available for public right now and it is not recommended to change the core frequency like this as incorrect configuration of the PLL can lead to fatal effects to the SoC.
G Kowshik
Thank you, Kowshik.
I have a follow up question just for my better understanding -
what is the difference between the core clock frequency changed in GEL file above and the clock configuration in SysConfig?
If I change the clock frequency in SysConfig, where does this clock frequency change affect?
Thank you!
Hi Sue,
I missed one more change, you need to update the divider value to get the 300Mhz to the core
Hi Sue,
If I change the clock frequency in SysConfig, where does this clock frequency change affect?Thank you!
That Clock is actually not the Core clock. If you look at the long description of this module, it is basically a timer module that can be used as SysClk (as in Cortex-M controllers which have native sysclk timer) please don't confuse it to the Core Clock or Clock tree.
