Part Number: AM2732
Hello
I developed a board based on am2732 with an on board xds110 , I was wondering if you have the binary file to be downloaded in the TM4C129 to debug and communicate with the AM2732.
Amine
Part Number: AM2732
Hello
Amine
Are you planning to use TM4C129 as xds110 ? If so you could refer to https://www.ti.com/lit/ug/spruiy1a/spruiy1a.pdf AM273x EVM user guide and section 4.4.3 PC Connection.
So basically the XDS110 firmware is loaded to TM4C129 to act as XDS110.
Best Regards, Shiv
Thank you for your help but I designed a new board based on TIDA 020047 reference board. By default there's no fw in the TM4C129 component. So in this case which code should I loaded into before starting with AM2732?
