Part Number: RM46L852
Other Parts Discussed in Thread: HALCOGEN,
Hello Team,
I am new to TI. i just started learning HERCULES MCU's because i need this for my Project.
i bought the LaunchPad Board RM46L852.and started learning by using CCS and HALCOGEN.
i did small program (below)
int main(void)
int counter = 0;
++counter;
return 0;
check this e2e forum for the error i am also haviing the same problem
as per this i have to generate the halcogen code and then debug
i have generated the code and then i am getting the following error after flashing
CortexR4: GEL Output: Memory Map Setup for Flash @ Address 0x0CortexR4: GEL Output: Memory Map Setup for Flash @ Address 0x0 due to System Reset
CortexR4: Error: (Error -2063 @ 0x0) Unable to reset device. Power-cycle the board. If error persists, confirm configuration and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 9.11.0.00128)
CortexR4: Trouble Halting Target CPU: (Error -2064 @ 0x0) Unable to read device status. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 9.11.0.00128)
CortexR4: Error: (Error -1170 @ 0x0) Unable to access the DAP. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 9.11.0.00128)
CortexR4: Unable to determine target status after 20 attempts
CortexR4: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
and i gone through with this website also https://software-dl.ti.com/ccs/esd/documents/ccs_debugging_jtag_connectivity_issues.html
and changed the jtag clock speed but no luck.
i got stucked here kindly help
Thanks and Regards
Bavi U M
