Part Number: TMS570LC4357
Hi Team,
1) Configuration register HETGCR.is=0, using the N2HET module as per section 23.4.4 of the manual. However, when the CPU is halted at the breakpoint, the N2HET module does not stop functioning. Is additional configuration or action required?
2) Configure breakpoints as described in Section 23.1.7 of the manual, but after the N2HET is stopped, the CPU does not stop and continues to function normally.
3) Follow section 23.1.7 to configure the CPU and N2HET restart. However, the N2HET works directly without waiting for the CPU to exit the debug state. Does the restart require additional configuration or action?
Could you please help check this case? Thanks.
Cherry
