Part Number: TMDS273GPEVM
Other Parts Discussed in Thread: AM2732
We could make a communication between the ECU and the PC by configuring the IP statically.
Does anyone know how to configure the PORT??
Hi Cl Xu,
Can you please elaborate what exact configuration or changes do you want in the Port? I see you are able to communicate between ECU and the PC, right?
Shaunak
Hi Cl Xu,
In case of TCP Client example, in app_tcpclient.c there will be a MACRO HOST_SERVER_PORT which defines the host server port number, by default it is set to 8888.
Similarly, if you are using UDP Client example, there will be a MACRO SOCK_HOST_SERVER_PORT in app_udpclient.c
Please modify it as per your requirement, save the file, rebuild the example and test the new binary. Do let me know if you face any issues,
Shaunak
Hi Cl Xu,
You can use the netconn_bind() API, although we have not tested it for Client-side applications to set a port number to Client. But it should work, we can give it a try.
You can pass the desired port you want for client in this function.
Shaunak
