Part Number: AM2634
Hello TI Team
We need for our project a precompiled secure bootloader image. Is there any available for the latest version of AM2634?
Thank you in advance
Part Number: AM2634
Hello TI Team
Hi Panda Bear,
Do you need it for HS-FS or HS-SE device ?
Aakash
Hello Aakash
the device codes are those:
AM2634COKFHMZCZRQ1
AM2634BOLFHMZCZRQ1
Both are HS-FS (secure boot capable) as we sell them... really no other option available. Once you fuse the keys they get converted to HS-SE and will require secure boot SW flow. Did you fuse anything yet?
Regards, Frank
To support Frank's response, you can use the script to identify if the device is HS-FS or HS-SE - https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1170785/faq-mcu-plus-sdk-am243x-how-to-identify-if-the-device-is-gp-device-or-hs-device
Hope it helps.
Aakash
