LP-AM243: file default_sbl_ospi.cfg from SDK goes wrong
Part Number: LP-AM243
Hi Ti Team,
            I am trying to follow "Flash a Hello World example". When I ran the Python command, there was an error as the screen-shot shows
            The version of my SDK is mcu_plus_sdk_am243x_09_00_00_35.
         I copy the file default_sbl_ospi.cfg's line-32, as the following...
        --file=../../examples/drivers/ipc/ipc_notify_echo/am243x-lp/system_freertos_nortos/ipc_notify_echo_system.release.appimage_xip --operation=flash-xip
         And I checked the folder ./examples/drivers/ipc/ipc_notify_echo/am243x-lp/system_freertos_nortos/i, there is no file named: ipc_notify_echo_system.release.appimage_xip
         Could you tell me how can I resolve it?
Chunyang
  • Hi Chunyang,
    You could import any example on CCS and build it to obtain the appimage_xip in the Debug folder. Then give the path to that file in line 32 of default_sbl_ospi.cfg. Let me know if you face any further issues.
    Sahana
