Other Parts Discussed in Thread: TMDS243EVM, AM6442, TMDS64EVM
All:
a few questions on consistencies on this page that I have:
dfu-util
The note:
" USB2.0 DFU driver and application is tested with dfu-util verson dfu-util 0.11-dev
and dfu-util 0.8-dev
. It is recomended to use that same version as mentioned."
Should a user be using dfu-util v11 or v8 in the Win 10 environment?
Steps to install windows generic USB drivers.
wrt Zadig :
you have Zadig 2.7 hyperlinked, i.e. https://github.com/pbatard/libwdi/releases/download/v1.4.1/zadig-2.7.exe
I have 2.7 installed
1) I saw https://github.com/pbatard/libwdi/releases/tag/v1.5.0 has zadig-2.8.exe available - any good reason to use that newer version?
2) When I run Zadig 2.7 per options->list all device, I get the following view:
a - I do not see a AM64x DFU option -- only the "XDS110" ones -- is there a mismatch/update needed? I have my 2 USB cables to the TMDS243EVM connected directly into the laptop ports.
b - I have attached the advanced log.
Zadig 2.7.765 Windows 10 Pro, 64-bit (Build 19045.3448) ini file 'zadig.ini' not found in 'C:\windows\system32' - default parameters will be used default driver set to 'WinUSB' 0 devices found. 10 devices found. libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_01 libwdi:debug [wdi_create_list] Compatible ID: USB\MS_COMP_WINUSB libwdi:debug [wdi_create_list] Driver version: 10.0.19041.1 libwdi:debug [wdi_create_list] WINUSB USB device (0): USB\VID_03F0&PID_0488&MI_01\8&2F9E72C5&0&0001 libwdi:debug [wdi_create_list] Device description: 'Vendor Interface (Interface 1)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_413C&PID_2113&REV_0108&MI_01 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (2): USB\VID_413C&PID_2113&MI_01\9&99DE6B2&0&0001 libwdi:debug [wdi_create_list] Device description: 'Dell KB216 Wired Keyboard (Interface 1)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_413C&PID_2113&REV_0108&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_01&Prot_01 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (3): USB\VID_413C&PID_2113&MI_00\9&99DE6B2&0&0000 libwdi:debug [wdi_create_list] Device description: 'Dell KB216 Wired Keyboard (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (4): USB\VID_03F0&PID_0488&MI_02\8&2F9E72C5&0&0002 libwdi:debug [wdi_create_list] Device description: 'HID Interface (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_8087&PID_0026&REV_0002 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_E0&SubClass_01&Prot_01 libwdi:debug [wdi_create_list] Driver version: 22.250.0.2 libwdi:debug [wdi_create_list] BTHUSB USB device (5): USB\VID_8087&PID_0026\5&10D09A20&0&14 libwdi:debug [wdi_create_list] Device description: 'Intel(R) Wireless Bluetooth(R)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0408&PID_5347&REV_0009&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_0e&SubClass_03&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.22000.20276 libwdi:debug [wdi_create_list] usbvideo USB device (6): USB\VID_0408&PID_5347&MI_02\6&F241D84&0&0002 libwdi:debug [wdi_create_list] Device description: 'HP IR Camera (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0408&PID_5347&REV_0009&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_0e&SubClass_03&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.22000.20276 libwdi:debug [wdi_create_list] usbvideo USB device (7): USB\VID_0408&PID_5347&MI_00\6&F241D84&0&0000 libwdi:debug [wdi_create_list] Device description: 'HP HD Camera (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_04F2&PID_1825&REV_0301 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_01&Prot_02 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (10): USB\VID_04F2&PID_1825\5&10D09A20&0&4 libwdi:debug [wdi_create_list] Device description: ' Wireless Device' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_06CB&PID_00F0&REV_0000 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_FF&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 6.0.117.1110 libwdi:debug [wdi_create_list] WUDFRd USB device (12): USB\VID_06CB&PID_00F0\9B2F2A7A19D2 libwdi:debug [wdi_create_list] Device description: 'Synaptics FS7605 Touch Fingerprint Sensor with PurePrint(TM)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_11&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.1 libwdi:debug [wdi_create_list] WINUSB USB device (15): USB\VID_03F0&PID_0488&MI_00\8&2F9E72C5&0&0000 libwdi:debug [wdi_create_list] Device description: 'HP Thunderbolt Dock G4 (Interface 0)' 9 devices found. libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_01 libwdi:debug [wdi_create_list] Compatible ID: USB\MS_COMP_WINUSB libwdi:debug [wdi_create_list] Driver version: 10.0.19041.1 libwdi:debug [wdi_create_list] WINUSB USB device (0): USB\VID_03F0&PID_0488&MI_01\8&2F9E72C5&0&0001 libwdi:debug [wdi_create_list] Device description: 'Vendor Interface (Interface 1)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_413C&PID_2113&REV_0108&MI_01 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (2): USB\VID_413C&PID_2113&MI_01\9&99DE6B2&0&0001 libwdi:debug [wdi_create_list] Device description: 'Dell KB216 Wired Keyboard (Interface 1)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_413C&PID_2113&REV_0108&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_01&Prot_01 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (3): USB\VID_413C&PID_2113&MI_00\9&99DE6B2&0&0000 libwdi:debug [wdi_create_list] Device description: 'Dell KB216 Wired Keyboard (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (4): USB\VID_03F0&PID_0488&MI_02\8&2F9E72C5&0&0002 libwdi:debug [wdi_create_list] Device description: 'HID Interface (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_8087&PID_0026&REV_0002 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_E0&SubClass_01&Prot_01 libwdi:debug [wdi_create_list] Driver version: 22.250.0.2 libwdi:debug [wdi_create_list] BTHUSB USB device (5): USB\VID_8087&PID_0026\5&10D09A20&0&14 libwdi:debug [wdi_create_list] Device description: 'Intel(R) Wireless Bluetooth(R)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0408&PID_5347&REV_0009&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_0e&SubClass_03&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.22000.20276 libwdi:debug [wdi_create_list] usbvideo USB device (6): USB\VID_0408&PID_5347&MI_02\6&F241D84&0&0002 libwdi:debug [wdi_create_list] Device description: 'HP IR Camera (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0408&PID_5347&REV_0009&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_0e&SubClass_03&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.22000.20276 libwdi:debug [wdi_create_list] usbvideo USB device (7): USB\VID_0408&PID_5347&MI_00\6&F241D84&0&0000 libwdi:debug [wdi_create_list] Device description: 'HP HD Camera (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_06CB&PID_00F0&REV_0000 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_FF&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 6.0.117.1110 libwdi:debug [wdi_create_list] WUDFRd USB device (11): USB\VID_06CB&PID_00F0\9B2F2A7A19D2 libwdi:debug [wdi_create_list] Device description: 'Synaptics FS7605 Touch Fingerprint Sensor with PurePrint(TM)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_11&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.1 libwdi:debug [wdi_create_list] WINUSB USB device (14): USB\VID_03F0&PID_0488&MI_00\8&2F9E72C5&0&0000 libwdi:debug [wdi_create_list] Device description: 'HP Thunderbolt Dock G4 (Interface 0)' 0 devices found. 9 devices found. libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_01 libwdi:debug [wdi_create_list] Compatible ID: USB\MS_COMP_WINUSB libwdi:debug [wdi_create_list] Driver version: 10.0.19041.1 libwdi:debug [wdi_create_list] WINUSB USB device (0): USB\VID_03F0&PID_0488&MI_01\8&2F9E72C5&0&0001 libwdi:debug [wdi_create_list] Device description: 'Vendor Interface (Interface 1)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_413C&PID_2113&REV_0108&MI_01 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (2): USB\VID_413C&PID_2113&MI_01\9&99DE6B2&0&0001 libwdi:debug [wdi_create_list] Device description: 'Dell KB216 Wired Keyboard (Interface 1)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_413C&PID_2113&REV_0108&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_01&Prot_01 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (3): USB\VID_413C&PID_2113&MI_00\9&99DE6B2&0&0000 libwdi:debug [wdi_create_list] Device description: 'Dell KB216 Wired Keyboard (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (4): USB\VID_03F0&PID_0488&MI_02\8&2F9E72C5&0&0002 libwdi:debug [wdi_create_list] Device description: 'HID Interface (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_8087&PID_0026&REV_0002 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_E0&SubClass_01&Prot_01 libwdi:debug [wdi_create_list] Driver version: 22.250.0.2 libwdi:debug [wdi_create_list] BTHUSB USB device (5): USB\VID_8087&PID_0026\5&10D09A20&0&14 libwdi:debug [wdi_create_list] Device description: 'Intel(R) Wireless Bluetooth(R)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0408&PID_5347&REV_0009&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_0e&SubClass_03&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.22000.20276 libwdi:debug [wdi_create_list] usbvideo USB device (6): USB\VID_0408&PID_5347&MI_02\6&F241D84&0&0002 libwdi:debug [wdi_create_list] Device description: 'HP IR Camera (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0408&PID_5347&REV_0009&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_0e&SubClass_03&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.22000.20276 libwdi:debug [wdi_create_list] usbvideo USB device (7): USB\VID_0408&PID_5347&MI_00\6&F241D84&0&0000 libwdi:debug [wdi_create_list] Device description: 'HP HD Camera (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_06CB&PID_00F0&REV_0000 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_FF&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 6.0.117.1110 libwdi:debug [wdi_create_list] WUDFRd USB device (11): USB\VID_06CB&PID_00F0\9B2F2A7A19D2 libwdi:debug [wdi_create_list] Device description: 'Synaptics FS7605 Touch Fingerprint Sensor with PurePrint(TM)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_11&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.1 libwdi:debug [wdi_create_list] WINUSB USB device (14): USB\VID_03F0&PID_0488&MI_00\8&2F9E72C5&0&0000 libwdi:debug [wdi_create_list] Device description: 'HP Thunderbolt Dock G4 (Interface 0)' 9 devices found. libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_01 libwdi:debug [wdi_create_list] Compatible ID: USB\MS_COMP_WINUSB libwdi:debug [wdi_create_list] Driver version: 10.0.19041.1 libwdi:debug [wdi_create_list] WINUSB USB device (0): USB\VID_03F0&PID_0488&MI_01\8&2F9E72C5&0&0001 libwdi:debug [wdi_create_list] Device description: 'Vendor Interface (Interface 1)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_413C&PID_2113&REV_0108&MI_01 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (2): USB\VID_413C&PID_2113&MI_01\9&99DE6B2&0&0001 libwdi:debug [wdi_create_list] Device description: 'Dell KB216 Wired Keyboard (Interface 1)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_413C&PID_2113&REV_0108&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_01&Prot_01 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (3): USB\VID_413C&PID_2113&MI_00\9&99DE6B2&0&0000 libwdi:debug [wdi_create_list] Device description: 'Dell KB216 Wired Keyboard (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (4): USB\VID_03F0&PID_0488&MI_02\8&2F9E72C5&0&0002 libwdi:debug [wdi_create_list] Device description: 'HID Interface (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_8087&PID_0026&REV_0002 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_E0&SubClass_01&Prot_01 libwdi:debug [wdi_create_list] Driver version: 22.250.0.2 libwdi:debug [wdi_create_list] BTHUSB USB device (5): USB\VID_8087&PID_0026\5&10D09A20&0&14 libwdi:debug [wdi_create_list] Device description: 'Intel(R) Wireless Bluetooth(R)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0408&PID_5347&REV_0009&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_0e&SubClass_03&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.22000.20276 libwdi:debug [wdi_create_list] usbvideo USB device (6): USB\VID_0408&PID_5347&MI_02\6&F241D84&0&0002 libwdi:debug [wdi_create_list] Device description: 'HP IR Camera (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0408&PID_5347&REV_0009&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_0e&SubClass_03&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.22000.20276 libwdi:debug [wdi_create_list] usbvideo USB device (7): USB\VID_0408&PID_5347&MI_00\6&F241D84&0&0000 libwdi:debug [wdi_create_list] Device description: 'HP HD Camera (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_06CB&PID_00F0&REV_0000 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_FF&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 6.0.117.1110 libwdi:debug [wdi_create_list] WUDFRd USB device (11): USB\VID_06CB&PID_00F0\9B2F2A7A19D2 libwdi:debug [wdi_create_list] Device description: 'Synaptics FS7605 Touch Fingerprint Sensor with PurePrint(TM)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_11&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.1 libwdi:debug [wdi_create_list] WINUSB USB device (14): USB\VID_03F0&PID_0488&MI_00\8&2F9E72C5&0&0000 libwdi:debug [wdi_create_list] Device description: 'HP Thunderbolt Dock G4 (Interface 0)' 14 devices found. libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_01 libwdi:debug [wdi_create_list] Compatible ID: USB\MS_COMP_WINUSB libwdi:debug [wdi_create_list] Driver version: 10.0.19041.1 libwdi:debug [wdi_create_list] WINUSB USB device (0): USB\VID_03F0&PID_0488&MI_01\8&2F9E72C5&0&0001 libwdi:debug [wdi_create_list] Device description: 'Vendor Interface (Interface 1)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_413C&PID_2113&REV_0108&MI_01 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (2): USB\VID_413C&PID_2113&MI_01\9&99DE6B2&0&0001 libwdi:debug [wdi_create_list] Device description: 'Dell KB216 Wired Keyboard (Interface 1)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_413C&PID_2113&REV_0108&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_01&Prot_01 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (3): USB\VID_413C&PID_2113&MI_00\9&99DE6B2&0&0000 libwdi:debug [wdi_create_list] Device description: 'Dell KB216 Wired Keyboard (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (4): USB\VID_03F0&PID_0488&MI_02\8&2F9E72C5&0&0002 libwdi:debug [wdi_create_list] Device description: 'HID Interface (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_8087&PID_0026&REV_0002 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_E0&SubClass_01&Prot_01 libwdi:debug [wdi_create_list] Driver version: 22.250.0.2 libwdi:debug [wdi_create_list] BTHUSB USB device (5): USB\VID_8087&PID_0026\5&10D09A20&0&14 libwdi:debug [wdi_create_list] Device description: 'Intel(R) Wireless Bluetooth(R)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0408&PID_5347&REV_0009&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_0e&SubClass_03&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.22000.20276 libwdi:debug [wdi_create_list] usbvideo USB device (6): USB\VID_0408&PID_5347&MI_02\6&F241D84&0&0002 libwdi:debug [wdi_create_list] Device description: 'HP IR Camera (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0408&PID_5347&REV_0009&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_0e&SubClass_03&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.22000.20276 libwdi:debug [wdi_create_list] usbvideo USB device (7): USB\VID_0408&PID_5347&MI_00\6&F241D84&0&0000 libwdi:debug [wdi_create_list] Device description: 'HP HD Camera (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0451&PID_BEF3&REV_0100&MI_05 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (10): USB\VID_0451&PID_BEF3&MI_05\6&371B1B&0&0005 libwdi:debug [wdi_create_list] Device description: 'XDS110 CMSIS-DAP (Interface 5)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0451&PID_BEF3&REV_0100&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_ff&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 2.0.0.2 libwdi:debug [wdi_create_list] WinUSB USB device (11): USB\VID_0451&PID_BEF3&MI_02\6&371B1B&0&0002 libwdi:debug [wdi_create_list] Device description: 'XDS110 (03.00.00.26) Embed with CMSIS-DAP (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_06CB&PID_00F0&REV_0000 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_FF&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 6.0.117.1110 libwdi:debug [wdi_create_list] WUDFRd USB device (13): USB\VID_06CB&PID_00F0\9B2F2A7A19D2 libwdi:debug [wdi_create_list] Device description: 'Synaptics FS7605 Touch Fingerprint Sensor with PurePrint(TM)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0451&PID_BEF3&REV_0100&MI_06 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_ff&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 2.0.0.2 libwdi:debug [wdi_create_list] WinUSB USB device (14): USB\VID_0451&PID_BEF3&MI_06\6&371B1B&0&0006 libwdi:debug [wdi_create_list] Device description: 'XDS110 (03.00.00.26) Embed with CMSIS-DAP (Interface 6)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0451&PID_BEF3&REV_0100&MI_03 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_02&SubClass_02&Prot_01 libwdi:debug [wdi_create_list] Driver version: 2.0.0.2 libwdi:debug [wdi_create_list] usbser USB device (18): USB\VID_0451&PID_BEF3&MI_03\6&371B1B&0&0003 libwdi:debug [wdi_create_list] Device description: 'XDS110 (03.00.00.26) Embed with CMSIS-DAP (Interface 3)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_11&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.1 libwdi:debug [wdi_create_list] WINUSB USB device (19): USB\VID_03F0&PID_0488&MI_00\8&2F9E72C5&0&0000 libwdi:debug [wdi_create_list] Device description: 'HP Thunderbolt Dock G4 (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0451&PID_BEF3&REV_0100&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_02&SubClass_02&Prot_01 libwdi:debug [wdi_create_list] Driver version: 2.0.0.2 libwdi:debug [wdi_create_list] usbser USB device (20): USB\VID_0451&PID_BEF3&MI_00\6&371B1B&0&0000 libwdi:debug [wdi_create_list] Device description: 'XDS110 (03.00.00.26) Embed with CMSIS-DAP (Interface 0)' 18 devices found. libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_01 libwdi:debug [wdi_create_list] Compatible ID: USB\MS_COMP_WINUSB libwdi:debug [wdi_create_list] Driver version: 10.0.19041.1 libwdi:debug [wdi_create_list] WINUSB USB device (0): USB\VID_03F0&PID_0488&MI_01\8&2F9E72C5&0&0001 libwdi:debug [wdi_create_list] Device description: 'Vendor Interface (Interface 1)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_413C&PID_2113&REV_0108&MI_01 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (2): USB\VID_413C&PID_2113&MI_01\9&99DE6B2&0&0001 libwdi:debug [wdi_create_list] Device description: 'Dell KB216 Wired Keyboard (Interface 1)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_413C&PID_2113&REV_0108&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_01&Prot_01 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (3): USB\VID_413C&PID_2113&MI_00\9&99DE6B2&0&0000 libwdi:debug [wdi_create_list] Device description: 'Dell KB216 Wired Keyboard (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0403&PID_6011&REV_0800&MI_01 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_ff&SubClass_ff&Prot_ff libwdi:debug [wdi_create_list] Driver version: 2.12.36.4 libwdi:debug [wdi_create_list] FTDIBUS USB device (4): USB\VID_0403&PID_6011&MI_01\8&1FB874A0&0&0001 libwdi:debug [wdi_create_list] Device description: 'USB <-> Serial Converter (Interface 1)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (5): USB\VID_03F0&PID_0488&MI_02\8&2F9E72C5&0&0002 libwdi:debug [wdi_create_list] Device description: 'HID Interface (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_8087&PID_0026&REV_0002 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_E0&SubClass_01&Prot_01 libwdi:debug [wdi_create_list] Driver version: 22.250.0.2 libwdi:debug [wdi_create_list] BTHUSB USB device (6): USB\VID_8087&PID_0026\5&10D09A20&0&14 libwdi:debug [wdi_create_list] Device description: 'Intel(R) Wireless Bluetooth(R)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0408&PID_5347&REV_0009&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_0e&SubClass_03&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.22000.20276 libwdi:debug [wdi_create_list] usbvideo USB device (7): USB\VID_0408&PID_5347&MI_02\6&F241D84&0&0002 libwdi:debug [wdi_create_list] Device description: 'HP IR Camera (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0408&PID_5347&REV_0009&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_0e&SubClass_03&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.22000.20276 libwdi:debug [wdi_create_list] usbvideo USB device (8): USB\VID_0408&PID_5347&MI_00\6&F241D84&0&0000 libwdi:debug [wdi_create_list] Device description: 'HP HD Camera (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0403&PID_6011&REV_0800&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_ff&SubClass_ff&Prot_ff libwdi:debug [wdi_create_list] Driver version: 2.12.36.4 libwdi:debug [wdi_create_list] FTDIBUS USB device (9): USB\VID_0403&PID_6011&MI_02\8&1FB874A0&0&0002 libwdi:debug [wdi_create_list] Device description: 'USB <-> Serial Converter (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0451&PID_BEF3&REV_0100&MI_05 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (12): USB\VID_0451&PID_BEF3&MI_05\6&371B1B&0&0005 libwdi:debug [wdi_create_list] Device description: 'XDS110 CMSIS-DAP (Interface 5)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0451&PID_BEF3&REV_0100&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_ff&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 2.0.0.2 libwdi:debug [wdi_create_list] WinUSB USB device (13): USB\VID_0451&PID_BEF3&MI_02\6&371B1B&0&0002 libwdi:debug [wdi_create_list] Device description: 'XDS110 (03.00.00.26) Embed with CMSIS-DAP (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0403&PID_6011&REV_0800&MI_03 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_ff&SubClass_ff&Prot_ff libwdi:debug [wdi_create_list] Driver version: 2.12.36.4 libwdi:debug [wdi_create_list] FTDIBUS USB device (14): USB\VID_0403&PID_6011&MI_03\8&1FB874A0&0&0003 libwdi:debug [wdi_create_list] Device description: 'USB <-> Serial Converter (Interface 3)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_06CB&PID_00F0&REV_0000 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_FF&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 6.0.117.1110 libwdi:debug [wdi_create_list] WUDFRd USB device (16): USB\VID_06CB&PID_00F0\9B2F2A7A19D2 libwdi:debug [wdi_create_list] Device description: 'Synaptics FS7605 Touch Fingerprint Sensor with PurePrint(TM)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0451&PID_BEF3&REV_0100&MI_06 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_ff&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 2.0.0.2 libwdi:debug [wdi_create_list] WinUSB USB device (17): USB\VID_0451&PID_BEF3&MI_06\6&371B1B&0&0006 libwdi:debug [wdi_create_list] Device description: 'XDS110 (03.00.00.26) Embed with CMSIS-DAP (Interface 6)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0451&PID_BEF3&REV_0100&MI_03 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_02&SubClass_02&Prot_01 libwdi:debug [wdi_create_list] Driver version: 2.0.0.2 libwdi:debug [wdi_create_list] usbser USB device (21): USB\VID_0451&PID_BEF3&MI_03\6&371B1B&0&0003 libwdi:debug [wdi_create_list] Device description: 'XDS110 (03.00.00.26) Embed with CMSIS-DAP (Interface 3)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_11&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.1 libwdi:debug [wdi_create_list] WINUSB USB device (23): USB\VID_03F0&PID_0488&MI_00\8&2F9E72C5&0&0000 libwdi:debug [wdi_create_list] Device description: 'HP Thunderbolt Dock G4 (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0451&PID_BEF3&REV_0100&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_02&SubClass_02&Prot_01 libwdi:debug [wdi_create_list] Driver version: 2.0.0.2 libwdi:debug [wdi_create_list] usbser USB device (24): USB\VID_0451&PID_BEF3&MI_00\6&371B1B&0&0000 libwdi:debug [wdi_create_list] Device description: 'XDS110 (03.00.00.26) Embed with CMSIS-DAP (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0403&PID_6011&REV_0800&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_ff&SubClass_ff&Prot_ff libwdi:debug [wdi_create_list] Driver version: 2.12.36.4 libwdi:debug [wdi_create_list] FTDIBUS USB device (26): USB\VID_0403&PID_6011&MI_00\8&1FB874A0&0&0000 libwdi:debug [wdi_create_list] Device description: 'USB <-> Serial Converter (Interface 0)' 18 devices found. libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_01 libwdi:debug [wdi_create_list] Compatible ID: USB\MS_COMP_WINUSB libwdi:debug [wdi_create_list] Driver version: 10.0.19041.1 libwdi:debug [wdi_create_list] WINUSB USB device (0): USB\VID_03F0&PID_0488&MI_01\8&2F9E72C5&0&0001 libwdi:debug [wdi_create_list] Device description: 'Vendor Interface (Interface 1)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_413C&PID_2113&REV_0108&MI_01 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (2): USB\VID_413C&PID_2113&MI_01\9&99DE6B2&0&0001 libwdi:debug [wdi_create_list] Device description: 'Dell KB216 Wired Keyboard (Interface 1)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_413C&PID_2113&REV_0108&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_01&Prot_01 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (3): USB\VID_413C&PID_2113&MI_00\9&99DE6B2&0&0000 libwdi:debug [wdi_create_list] Device description: 'Dell KB216 Wired Keyboard (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0403&PID_6011&REV_0800&MI_01 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_ff&SubClass_ff&Prot_ff libwdi:debug [wdi_create_list] Driver version: 2.12.36.4 libwdi:debug [wdi_create_list] FTDIBUS USB device (4): USB\VID_0403&PID_6011&MI_01\8&1FB874A0&0&0001 libwdi:debug [wdi_create_list] Device description: 'USB <-> Serial Converter (Interface 1)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (5): USB\VID_03F0&PID_0488&MI_02\8&2F9E72C5&0&0002 libwdi:debug [wdi_create_list] Device description: 'HID Interface (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_8087&PID_0026&REV_0002 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_E0&SubClass_01&Prot_01 libwdi:debug [wdi_create_list] Driver version: 22.250.0.2 libwdi:debug [wdi_create_list] BTHUSB USB device (6): USB\VID_8087&PID_0026\5&10D09A20&0&14 libwdi:debug [wdi_create_list] Device description: 'Intel(R) Wireless Bluetooth(R)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0408&PID_5347&REV_0009&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_0e&SubClass_03&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.22000.20276 libwdi:debug [wdi_create_list] usbvideo USB device (7): USB\VID_0408&PID_5347&MI_02\6&F241D84&0&0002 libwdi:debug [wdi_create_list] Device description: 'HP IR Camera (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0408&PID_5347&REV_0009&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_0e&SubClass_03&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.22000.20276 libwdi:debug [wdi_create_list] usbvideo USB device (8): USB\VID_0408&PID_5347&MI_00\6&F241D84&0&0000 libwdi:debug [wdi_create_list] Device description: 'HP HD Camera (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0403&PID_6011&REV_0800&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_ff&SubClass_ff&Prot_ff libwdi:debug [wdi_create_list] Driver version: 2.12.36.4 libwdi:debug [wdi_create_list] FTDIBUS USB device (9): USB\VID_0403&PID_6011&MI_02\8&1FB874A0&0&0002 libwdi:debug [wdi_create_list] Device description: 'USB <-> Serial Converter (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0451&PID_BEF3&REV_0100&MI_05 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (12): USB\VID_0451&PID_BEF3&MI_05\6&371B1B&0&0005 libwdi:debug [wdi_create_list] Device description: 'XDS110 CMSIS-DAP (Interface 5)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0451&PID_BEF3&REV_0100&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_ff&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 2.0.0.2 libwdi:debug [wdi_create_list] WinUSB USB device (13): USB\VID_0451&PID_BEF3&MI_02\6&371B1B&0&0002 libwdi:debug [wdi_create_list] Device description: 'XDS110 (03.00.00.26) Embed with CMSIS-DAP (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0403&PID_6011&REV_0800&MI_03 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_ff&SubClass_ff&Prot_ff libwdi:debug [wdi_create_list] Driver version: 2.12.36.4 libwdi:debug [wdi_create_list] FTDIBUS USB device (14): USB\VID_0403&PID_6011&MI_03\8&1FB874A0&0&0003 libwdi:debug [wdi_create_list] Device description: 'USB <-> Serial Converter (Interface 3)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_06CB&PID_00F0&REV_0000 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_FF&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 6.0.117.1110 libwdi:debug [wdi_create_list] WUDFRd USB device (16): USB\VID_06CB&PID_00F0\9B2F2A7A19D2 libwdi:debug [wdi_create_list] Device description: 'Synaptics FS7605 Touch Fingerprint Sensor with PurePrint(TM)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0451&PID_BEF3&REV_0100&MI_06 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_ff&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 2.0.0.2 libwdi:debug [wdi_create_list] WinUSB USB device (17): USB\VID_0451&PID_BEF3&MI_06\6&371B1B&0&0006 libwdi:debug [wdi_create_list] Device description: 'XDS110 (03.00.00.26) Embed with CMSIS-DAP (Interface 6)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0451&PID_BEF3&REV_0100&MI_03 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_02&SubClass_02&Prot_01 libwdi:debug [wdi_create_list] Driver version: 2.0.0.2 libwdi:debug [wdi_create_list] usbser USB device (21): USB\VID_0451&PID_BEF3&MI_03\6&371B1B&0&0003 libwdi:debug [wdi_create_list] Device description: 'XDS110 (03.00.00.26) Embed with CMSIS-DAP (Interface 3)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_11&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.1 libwdi:debug [wdi_create_list] WINUSB USB device (23): USB\VID_03F0&PID_0488&MI_00\8&2F9E72C5&0&0000 libwdi:debug [wdi_create_list] Device description: 'HP Thunderbolt Dock G4 (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0451&PID_BEF3&REV_0100&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_02&SubClass_02&Prot_01 libwdi:debug [wdi_create_list] Driver version: 2.0.0.2 libwdi:debug [wdi_create_list] usbser USB device (24): USB\VID_0451&PID_BEF3&MI_00\6&371B1B&0&0000 libwdi:debug [wdi_create_list] Device description: 'XDS110 (03.00.00.26) Embed with CMSIS-DAP (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0403&PID_6011&REV_0800&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_ff&SubClass_ff&Prot_ff libwdi:debug [wdi_create_list] Driver version: 2.12.36.4 libwdi:debug [wdi_create_list] FTDIBUS USB device (26): USB\VID_0403&PID_6011&MI_00\8&1FB874A0&0&0000 libwdi:debug [wdi_create_list] Device description: 'USB <-> Serial Converter (Interface 0)' 18 devices found. libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_01 libwdi:debug [wdi_create_list] Compatible ID: USB\MS_COMP_WINUSB libwdi:debug [wdi_create_list] Driver version: 10.0.19041.1 libwdi:debug [wdi_create_list] WINUSB USB device (0): USB\VID_03F0&PID_0488&MI_01\8&2F9E72C5&0&0001 libwdi:debug [wdi_create_list] Device description: 'Vendor Interface (Interface 1)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_413C&PID_2113&REV_0108&MI_01 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (2): USB\VID_413C&PID_2113&MI_01\9&99DE6B2&0&0001 libwdi:debug [wdi_create_list] Device description: 'Dell KB216 Wired Keyboard (Interface 1)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_413C&PID_2113&REV_0108&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_01&Prot_01 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (3): USB\VID_413C&PID_2113&MI_00\9&99DE6B2&0&0000 libwdi:debug [wdi_create_list] Device description: 'Dell KB216 Wired Keyboard (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0403&PID_6011&REV_0800&MI_01 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_ff&SubClass_ff&Prot_ff libwdi:debug [wdi_create_list] Driver version: 2.12.36.4 libwdi:debug [wdi_create_list] FTDIBUS USB device (4): USB\VID_0403&PID_6011&MI_01\8&1FB874A0&0&0001 libwdi:debug [wdi_create_list] Device description: 'USB <-> Serial Converter (Interface 1)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (5): USB\VID_03F0&PID_0488&MI_02\8&2F9E72C5&0&0002 libwdi:debug [wdi_create_list] Device description: 'HID Interface (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_8087&PID_0026&REV_0002 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_E0&SubClass_01&Prot_01 libwdi:debug [wdi_create_list] Driver version: 22.250.0.2 libwdi:debug [wdi_create_list] BTHUSB USB device (6): USB\VID_8087&PID_0026\5&10D09A20&0&14 libwdi:debug [wdi_create_list] Device description: 'Intel(R) Wireless Bluetooth(R)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0408&PID_5347&REV_0009&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_0e&SubClass_03&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.22000.20276 libwdi:debug [wdi_create_list] usbvideo USB device (7): USB\VID_0408&PID_5347&MI_02\6&F241D84&0&0002 libwdi:debug [wdi_create_list] Device description: 'HP IR Camera (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0408&PID_5347&REV_0009&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_0e&SubClass_03&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.22000.20276 libwdi:debug [wdi_create_list] usbvideo USB device (8): USB\VID_0408&PID_5347&MI_00\6&F241D84&0&0000 libwdi:debug [wdi_create_list] Device description: 'HP HD Camera (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0403&PID_6011&REV_0800&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_ff&SubClass_ff&Prot_ff libwdi:debug [wdi_create_list] Driver version: 2.12.36.4 libwdi:debug [wdi_create_list] FTDIBUS USB device (9): USB\VID_0403&PID_6011&MI_02\8&1FB874A0&0&0002 libwdi:debug [wdi_create_list] Device description: 'USB <-> Serial Converter (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0451&PID_BEF3&REV_0100&MI_05 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_03&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.3031 libwdi:debug [wdi_create_list] HidUsb USB device (12): USB\VID_0451&PID_BEF3&MI_05\6&371B1B&0&0005 libwdi:debug [wdi_create_list] Device description: 'XDS110 CMSIS-DAP (Interface 5)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0451&PID_BEF3&REV_0100&MI_02 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_ff&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 2.0.0.2 libwdi:debug [wdi_create_list] WinUSB USB device (13): USB\VID_0451&PID_BEF3&MI_02\6&371B1B&0&0002 libwdi:debug [wdi_create_list] Device description: 'XDS110 (03.00.00.26) Embed with CMSIS-DAP (Interface 2)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0403&PID_6011&REV_0800&MI_03 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_ff&SubClass_ff&Prot_ff libwdi:debug [wdi_create_list] Driver version: 2.12.36.4 libwdi:debug [wdi_create_list] FTDIBUS USB device (14): USB\VID_0403&PID_6011&MI_03\8&1FB874A0&0&0003 libwdi:debug [wdi_create_list] Device description: 'USB <-> Serial Converter (Interface 3)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_06CB&PID_00F0&REV_0000 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_FF&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 6.0.117.1110 libwdi:debug [wdi_create_list] WUDFRd USB device (16): USB\VID_06CB&PID_00F0\9B2F2A7A19D2 libwdi:debug [wdi_create_list] Device description: 'Synaptics FS7605 Touch Fingerprint Sensor with PurePrint(TM)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0451&PID_BEF3&REV_0100&MI_06 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_ff&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 2.0.0.2 libwdi:debug [wdi_create_list] WinUSB USB device (17): USB\VID_0451&PID_BEF3&MI_06\6&371B1B&0&0006 libwdi:debug [wdi_create_list] Device description: 'XDS110 (03.00.00.26) Embed with CMSIS-DAP (Interface 6)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0451&PID_BEF3&REV_0100&MI_03 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_02&SubClass_02&Prot_01 libwdi:debug [wdi_create_list] Driver version: 2.0.0.2 libwdi:debug [wdi_create_list] usbser USB device (21): USB\VID_0451&PID_BEF3&MI_03\6&371B1B&0&0003 libwdi:debug [wdi_create_list] Device description: 'XDS110 (03.00.00.26) Embed with CMSIS-DAP (Interface 3)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_03F0&PID_0488&REV_1746&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_11&SubClass_00&Prot_00 libwdi:debug [wdi_create_list] Driver version: 10.0.19041.1 libwdi:debug [wdi_create_list] WINUSB USB device (23): USB\VID_03F0&PID_0488&MI_00\8&2F9E72C5&0&0000 libwdi:debug [wdi_create_list] Device description: 'HP Thunderbolt Dock G4 (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0451&PID_BEF3&REV_0100&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_02&SubClass_02&Prot_01 libwdi:debug [wdi_create_list] Driver version: 2.0.0.2 libwdi:debug [wdi_create_list] usbser USB device (24): USB\VID_0451&PID_BEF3&MI_00\6&371B1B&0&0000 libwdi:debug [wdi_create_list] Device description: 'XDS110 (03.00.00.26) Embed with CMSIS-DAP (Interface 0)' libwdi:debug [wdi_create_list] Hardware ID: USB\VID_0403&PID_6011&REV_0800&MI_00 libwdi:debug [wdi_create_list] Compatible ID: USB\Class_ff&SubClass_ff&Prot_ff libwdi:debug [wdi_create_list] Driver version: 2.12.36.4 libwdi:debug [wdi_create_list] FTDIBUS USB device (26): USB\VID_0403&PID_6011&MI_00\8&1FB874A0&0&0000 libwdi:debug [wdi_create_list] Device description: 'USB <-> Serial Converter (Interface 0)'
