Hi team,
Are there any ways to improve the frequency accuracy of internal LF(32kHz, 3%)? My customer would like to improve it to 1% or 2%
Shunsuke Yamamoto
Hi team,
Shunsuke Yamamoto
Hi Yamamoto,
This is latext version data from datasheet, does this can meet customer requirement?
If you need more better accuracy, you have to use external LFXT.
Thanks!
Best Reagrds
Johnson
Hi Johnson,
Thank you for the reply. It is good to know that LFOSC accuracy is improved from the pre-released datasheet. Please let me check the customer.
Shunsuke Yamamoto
Hi Yamamoto,
Please let me know if other support for this thread.
Thanks!
Best Regards
Johnson
Hi Johnson,
Thank you for the answer. May I know the difference between temperature test conditions?
How did you measure these two conditons?
Shunsuke Yamamoto
Hi Yamatomo,
If the use case will work in -40C ~ 85C, the accuracy will keep -1.8% ~ 1.4%.
If the workn temperature oncrease, up to 125C, the accuracy will be get a little worse, see datasheet.
Thanks!
Best Regards
Johnson
