Part Number: TM4C1294NCPDT
Hello
I have a TM4C1294KCPDT microcontroller soldered on a PCB, I programmed it using the programmer of a TIVA TM4C1294NCP,
I have the program written in code composer, when you put a breakpoint in the program code and pause, it goes to an infinite loop.
This only happens when I run that code on the microcontroller that I soldered to the PCB, because when I run that same code on a
TIVA that loop does not occur. Could you give me any suggestions to fix the error?
I attach an image of the loop.
Beforehand thank you very much
Mayra
