Part Number: AM2432
Could you tell us what the bandwidth of the shared OCRAM ? xx bit width? xx MHz?
According to the following application note, we found that the Memory access latency of the shared on-chip SRAM is 63.75 ns (51 cycles).
https://www.ti.com/jp/lit/pdf/spracv1
I guess this latency is required at the first access only, not every bytes access.
Do you have any benchmark data of accessing from R5F to OCSRAM ? xxxMB/s ?
What's the access time in the case of Read/Write 4 x 32bit data ?
Thanks and regards,
Hideaki
