Part Number: TM4C129XNCZAD
Good Morning,
I'm developing a Modbus RTU to TCP bridge using the microcontroller TM4C129XNCZADI3, and I found on your website the attached application note that seems to describe the same application I need.
- I would like to port the code given by the link inside the attached pdf to the microcontroller TM4C129XNCZADI3. Is it possible?
- Or simply, is there another example (source code) that works with this microcontroller and that is compilable (created) with your IDE code composer studio?
(The source code in the example is a keil project, and by importing it in code composer is not so clear about which files are needed for the application.)
If you can help me, let me know.
Thank you in advance.
Best Regards.
Kevin
