AM2634-Q1: Can I use GPIO pin simulate CS (chip select) in McSPI?
Part Number: AM2634-Q1
Hi, Expert.
As title description,
Can we let MCSPI works in 3 PIN mode, and use a gpio for CS simulation?
Besides CS pin, what's difference between 3 PIN & 4 PIN MCSPI mode?
Gibbs
  • Hi Gibbs,
    You are correct. If you want to use the GPIO for manual CS enable, then you should use the 3-pin mode. The difference between 3-pin mode and 4-pin mode is whether the SPI drive will handle the CS enable automatically or not.
    Ming
