Part Number: AM2634
How to create a X.509 certificate and combine it with the image, to be booted when MCU + SDK, and OTP keywriter is provided
Hi Krishna P,
Can you please elaborate your use case ?
X.509 image generation and its merge with original image is something already showcased in tools/boot/signing/mcu_rom_image_gen.py
Generation -
Merge with Original Image -
What is the exact requirement from OTP Key Writer ?
Aakash
My doubt is that for generating the certificates should we always use gen_keywr_cert.sh file run the commands or edit the mcu_rom_image_gen.py file as per our requirements, or use mcu_rom_image_gen.py only for signing the image
Hi Krishna P,
Which certificate are you talking about ?
mcu_rom_image_gen.py is required for ROM certificates i.e. SBL and HSM Run Time Certificates.
For Key Writer Certificates gen_keywr_cert.sh is used. The extensions are completely different from SBL and HSM Run Time Certificate.
For App Image Certificates, it can either be TI defined (as in TIFS-MCU format) or you can choose to create your custom format in case you have custom HSM Run Time Firmware.
In MCU+ SDK, with the delivered TIFS-MCU image for App Image Signing - mcu_appimage_x509_cert_gen.py is used.
I hope it helps.
Aakash
Hi Aakash,
in the case of key writer crtificates, i used gen_keywr_cert.sh and an error occured saying it could'nt load ti_fek_public.pem file. and could not accese the secondary and primary cert .bin files, how can it be resolved
for configuring the OID's certificate what should be done, in case of SBL and HSM
Hi Krishna P,
Can you share which release are you using ? Can you also share the snippet of the issue ?
https://kernelmanic.com/2020/06/20/generating-certificates-with-custom-oids-using-openssl/
I hope it helps.
Aakash
