Part Number: TMS570LS3137
Hi
I tried ethernet communication with LWIP library but didn't work.
Is there any document or code example about TMS570LS3137 and LWIP?
Thanks.
Hi
Thanks.
Please refer below link:
6.1. Project 0 — Hercules Safety MCUs Documentation
Here you can also find git link for source code as well.
Thanks & regards,
Jagadish.
If you are using HDK board then make sure in S2 DIP switch you turned ON the ETHERNET:
Because in the past many customers experienced same issue without setting it properly.
Thanks & regards,
Jagadish.
Pinmuxing can also create this error, can you please make sure your pinmuxing configurations are proper?
Thanks & regards,
Jagadish.
