Part Number: MSPM0L1306
I have a customer using the BSL flash plugin feature with sysconfig. However when they try to populate the flash plugin function pointer, sysconfig does not generate the correct CRC value for the BSL configuration area. When the customer tried programming with the sysconfig generated non main crc the programming fails since the crc value is incorrect. Only when programming with a blank flash plugin pointer value (0xffff_ffff) does the crc calculation work correctly. Manually calculating the CRC for the BSL configuration and changing it in the hex file allows for proper programming.
Customer is using sysconfig 1.17. Was this issue addressed in a later sysconfig or is this still an issue?
Munan
