Part Number: TM4C129ENCPDT
My project is based upon the tcpEcho project, which is included within the TI RTOS examples. I have successfully integrated both EPI and SPI functionality into the project (I have external peripherals that require these interfaces). Everything was compiling and debugging just fine, and then I thought to add a SysConfig file to the project to make I/O configuration a bit more automated. That's when the compilation errors hit (see below).
I have tried: 1) deleting the SysConfig file; 2) Reverting to a previous state before adding the file; 3) making sure that SysConfig has been added to the "Products" under the Properties->General (it is v. 1.18.1). I am absolutely unsure what is causing this issue, and could use some support.
Thank you!
gmake: *** No rule to make target 'build-1973319167', needed by 'configPkg/linker.cmd'.
gmake: *** No rule to make target 'build-247187343', needed by 'configPkg/linker.cmd'.
gmake: *** No rule to make target 'build-920122993', needed by 'configPkg/compiler.opt'.
gmake: *** No rule to make target 'build-920122993', needed by 'configPkg/linker.cmd'.
gmake: Target 'all' not remade because of errors.
gmake.exe: *** [linker.cmd] Error 2
gmake.exe: *** [package/cfg/build_pem4f.xdl] Deleting file `package/cfg/build_pem4f.c'
gmake.exe: *** [package/cfg/build_pem4f.xdl] Deleting file `package/cfg/build_pem4f.h'
gmake.exe: *** Deleting file `linker.cmd'
gmake.exe: *** Deleting file `package/cfg/build_pem4f.xdl'
gmake[1]: *** [build-1973319167-inproc] Error 1
gmake[1]: *** [build-247187343-inproc] Error 1
gmake[1]: *** [build-920122993-inproc] Error 1
XDC runtime exception: java.io.IOException: file rename failed: C:\Projects\EMA\BETSI\MCU\betsi_mcu\BETSI_MCU_TCP_TI_RTOS\Debug\configPkg\package\cfg\build_pem4f7258533306165634967.tmp
