Part Number: MSPM0G3507
Hello.
Is there any document that shows how much error there is due to temperature effects regarding the Battery monitor function?
thank you.
Hello.
thank you.
Hello Kei,
Sorry I can't understand what you mean. Are you currently using the MSPM0G3507 for battery monitor or using Ti's dedicated battery monitor chip for battery monitor? What characteristics of the battery do you want to monitor?
Hello, Janz Bai.
Sorry for not being able to explain.
I would like to use MSPM0G's Battery/Supply Monitor.
I'm looking at the data sheet for that purpose, but there isn't much written about temperature, so I would like to get some information.
Excerpt from datasheet_mspm0g3507_revB.
Thank you.
Hello Kei,
I get what you mean. The supply monitor mentioned in this datasheet is used for POR / BOR supervisor to monitor the VDD, so the TYP value is at 25°C. Do you want to monitor the VDD supply or monitor the voltage of external independent battery?
Janz Bai
