Hello TI team,
sbl_keywriter project failed to build with CCS 12.50 enviroment as below. I used version: otp_keywriter_am243x_09_00_00-windows-installer.exe.
Since we use SDK 09.01 in our FW development, we would like to have the keywriter working in the same environment as well.
Your help is appreciated,
Hong
Hong@honzhzha-97VT0T3 MINGW64 /c/ti/mcu_plus_sdk_am243x_09_01_00_41/source/security/sbl_keywriter/am243x-evm/r5fss0-0_nortos/ti-arm-clang
$ gmake -j PROFILE=debug
Generating SysConfig files ...
C:/ti/sysconfig_1.18.0/nodejs/node C:/ti/sysconfig_1.18.0/dist/cli.js --product C:/ti/mcu_plus_sdk_am243x_09_01_00_41/.metadata/product.json --context r5fss0-0 --part ALV --package ALV --output generated/ ../example.syscfg
Running script...
Validating...
info: CONFIG_UART0(/drivers/uart/uart) baudRate: Actual Baudrate Possible: 115385 (0 % error)
info: /kernel/dpl/debug_log uartLog.baudRate: Actual Baudrate Possible: 115385 (0 % error)
Generating Code (example.syscfg)...
Writing C:\ti\mcu_plus_sdk_am243x_09_01_00_41\source\security\sbl_keywriter\am243x-evm\r5fss0-0_nortos\ti-arm-clang\generated\ti_dpl_config.c...
Writing C:\ti\mcu_plus_sdk_am243x_09_01_00_41\source\security\sbl_keywriter\am243x-evm\r5fss0-0_nortos\ti-arm-clang\generated\ti_dpl_config.h...
Writing C:\ti\mcu_plus_sdk_am243x_09_01_00_41\source\security\sbl_keywriter\am243x-evm\r5fss0-0_nortos\ti-arm-clang\generated\ti_drivers_config.c...
Writing C:\ti\mcu_plus_sdk_am243x_09_01_00_41\source\security\sbl_keywriter\am243x-evm\r5fss0-0_nortos\ti-arm-clang\generated\ti_drivers_config.h...
Writing C:\ti\mcu_plus_sdk_am243x_09_01_00_41\source\security\sbl_keywriter\am243x-evm\r5fss0-0_nortos\ti-arm-clang\generated\ti_drivers_open_close.c...
Writing C:\ti\mcu_plus_sdk_am243x_09_01_00_41\source\security\sbl_keywriter\am243x-evm\r5fss0-0_nortos\ti-arm-clang\generated\ti_drivers_open_close.h...
Writing C:\ti\mcu_plus_sdk_am243x_09_01_00_41\source\security\sbl_keywriter\am243x-evm\r5fss0-0_nortos\ti-arm-clang\generated\ti_pinmux_config.c...
Writing C:\ti\mcu_plus_sdk_am243x_09_01_00_41\source\security\sbl_keywriter\am243x-evm\r5fss0-0_nortos\ti-arm-clang\generated\ti_power_clock_config.c...
Writing C:\ti\mcu_plus_sdk_am243x_09_01_00_41\source\security\sbl_keywriter\am243x-evm\r5fss0-0_nortos\ti-arm-clang\generated\ti_board_config.c...
Writing C:\ti\mcu_plus_sdk_am243x_09_01_00_41\source\security\sbl_keywriter\am243x-evm\r5fss0-0_nortos\ti-arm-clang\generated\ti_board_config.h...
Writing C:\ti\mcu_plus_sdk_am243x_09_01_00_41\source\security\sbl_keywriter\am243x-evm\r5fss0-0_nortos\ti-arm-clang\generated\ti_board_open_close.c...
Writing C:\ti\mcu_plus_sdk_am243x_09_01_00_41\source\security\sbl_keywriter\am243x-evm\r5fss0-0_nortos\ti-arm-clang\generated\ti_board_open_close.h...
Writing C:\ti\mcu_plus_sdk_am243x_09_01_00_41\source\security\sbl_keywriter\am243x-evm\r5fss0-0_nortos\ti-arm-clang\generated\ti_enet_config.c...
Writing C:\ti\mcu_plus_sdk_am243x_09_01_00_41\source\security\sbl_keywriter\am243x-evm\r5fss0-0_nortos\ti-arm-clang\generated\ti_enet_config.h...
Writing C:\ti\mcu_plus_sdk_am243x_09_01_00_41\source\security\sbl_keywriter\am243x-evm\r5fss0-0_nortos\ti-arm-clang\generated\ti_enet_open_close.c...
Writing C:\ti\mcu_plus_sdk_am243x_09_01_00_41\source\security\sbl_keywriter\am243x-evm\r5fss0-0_nortos\ti-arm-clang\generated\ti_enet_open_close.h...
Writing C:\ti\mcu_plus_sdk_am243x_09_01_00_41\source\security\sbl_keywriter\am243x-evm\r5fss0-0_nortos\ti-arm-clang\generated\ti_enet_soc.c...
Writing C:\ti\mcu_plus_sdk_am243x_09_01_00_41\source\security\sbl_keywriter\am243x-evm\r5fss0-0_nortos\ti-arm-clang\generated\ti_enet_lwipif.c...
Writing C:\ti\mcu_plus_sdk_am243x_09_01_00_41\source\security\sbl_keywriter\am243x-evm\r5fss0-0_nortos\ti-arm-clang\generated\ti_enet_lwipif.h...
Writing C:\ti\mcu_plus_sdk_am243x_09_01_00_41\source\security\sbl_keywriter\am243x-evm\r5fss0-0_nortos\ti-arm-clang\generated\ti_pru_io_config.inc...
C:/ti/ccs1250/ccs/utils/cygwin/mkdir -p obj/debug/
Compiling: am243x:r5fss0-0:nortos:ti-arm-clang sbl_keywriter.debug.out: ../main.c
C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -Wall -Werror -g -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -D_DEBUG_=1 -IC:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c -IC:/ti/mcu_plus_sdk_am243x_09_01_00_41/source -Igenerated -DSOC_AM243X -MMD -o obj/debug//main.obj ../main.c
Compiling: am243x:r5fss0-0:nortos:ti-arm-clang sbl_keywriter.debug.out: ../keywriter_utils.c
C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -Wall -Werror -g -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -D_DEBUG_=1 -IC:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c -IC:/ti/mcu_plus_sdk_am243x_09_01_00_41/source -Igenerated -DSOC_AM243X -MMD -o obj/debug//keywriter_utils.obj ../keywriter_utils.c
Compiling: am243x:r5fss0-0:nortos:ti-arm-clang sbl_keywriter.debug.out: ../board.c
C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -Wall -Werror -g -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -D_DEBUG_=1 -IC:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c -IC:/ti/mcu_plus_sdk_am243x_09_01_00_41/source -Igenerated -DSOC_AM243X -MMD -o obj/debug//board.obj ../board.c
Compiling: am243x:r5fss0-0:nortos:ti-arm-clang sbl_keywriter.debug.out: generated/ti_drivers_config.c
C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -Wall -Werror -g -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -D_DEBUG_=1 -IC:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c -IC:/ti/mcu_plus_sdk_am243x_09_01_00_41/source -Igenerated -DSOC_AM243X -MMD -o obj/debug//ti_drivers_config.obj generated/ti_drivers_config.c
Compiling: am243x:r5fss0-0:nortos:ti-arm-clang sbl_keywriter.debug.out: generated/ti_drivers_open_close.c
C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -Wall -Werror -g -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -D_DEBUG_=1 -IC:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c -IC:/ti/mcu_plus_sdk_am243x_09_01_00_41/source -Igenerated -DSOC_AM243X -MMD -o obj/debug//ti_drivers_open_close.obj generated/ti_drivers_open_close.c
Compiling: am243x:r5fss0-0:nortos:ti-arm-clang sbl_keywriter.debug.out: generated/ti_board_config.c
C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -Wall -Werror -g -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -D_DEBUG_=1 -IC:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c -IC:/ti/mcu_plus_sdk_am243x_09_01_00_41/source -Igenerated -DSOC_AM243X -MMD -o obj/debug//ti_board_config.obj generated/ti_board_config.c
Compiling: am243x:r5fss0-0:nortos:ti-arm-clang sbl_keywriter.debug.out: generated/ti_board_open_close.c
C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -Wall -Werror -g -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -D_DEBUG_=1 -IC:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c -IC:/ti/mcu_plus_sdk_am243x_09_01_00_41/source -Igenerated -DSOC_AM243X -MMD -o obj/debug//ti_board_open_close.obj generated/ti_board_open_close.c
Compiling: am243x:r5fss0-0:nortos:ti-arm-clang sbl_keywriter.debug.out: generated/ti_dpl_config.c
C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -Wall -Werror -g -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -D_DEBUG_=1 -IC:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c -IC:/ti/mcu_plus_sdk_am243x_09_01_00_41/source -Igenerated -DSOC_AM243X -MMD -o obj/debug//ti_dpl_config.obj generated/ti_dpl_config.c
Compiling: am243x:r5fss0-0:nortos:ti-arm-clang sbl_keywriter.debug.out: generated/ti_pinmux_config.c
C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -Wall -Werror -g -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -D_DEBUG_=1 -IC:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c -IC:/ti/mcu_plus_sdk_am243x_09_01_00_41/source -Igenerated -DSOC_AM243X -MMD -o obj/debug//ti_pinmux_config.obj generated/ti_pinmux_config.c
Compiling: am243x:r5fss0-0:nortos:ti-arm-clang sbl_keywriter.debug.out: generated/ti_power_clock_config.c
C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -Wall -Werror -g -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -D_DEBUG_=1 -IC:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c -IC:/ti/mcu_plus_sdk_am243x_09_01_00_41/source -Igenerated -DSOC_AM243X -MMD -o obj/debug//ti_power_clock_config.obj generated/ti_power_clock_config.c
Linking: am243x:r5fss0-0:nortos:ti-arm-clang sbl_keywriter.debug.out ...
C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang -Wl,--diag_suppress=10063 -Wl,--ram_model -Wl,--reread_libs -Wl,-iC:/ti/mcu_plus_sdk_am243x_09_01_00_41/source/kernel/nortos/lib -Wl,-iC:/ti/mcu_plus_sdk_am243x_09_01_00_41/source/drivers/lib -Wl,-iC:/ti/mcu_plus_sdk_am243x_09_01_00_41/source/board/lib -Wl,-iC:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/lib -Wl,-m=sbl_keywriter.debug.map -o sbl_keywriter.debug.out obj/debug/main.obj obj/debug/keywriter_utils.obj obj/debug/board.obj obj/debug/ti_drivers_config.obj obj/debug/ti_drivers_open_close.obj obj/debug/ti_board_config.obj obj/debug/ti_board_open_close.obj obj/debug/ti_dpl_config.obj obj/debug/ti_pinmux_config.obj obj/debug/ti_power_clock_config.obj -lnortos.am243x.r5f.ti-arm-clang.debug.lib -ldrivers.am243x.r5f.ti-arm-clang.debug.lib -lboard.am243x.r5f.ti-arm-clang.debug.lib -llibc.a linker.cmd
"linker.cmd", line 18: error: program will not fit into available memory, or
the section contains a call site that requires a trampoline that can't be
generated for this section. placement with alignment fails for section
"GROUP_1" size 0x53089. Available memory ranges:
MSRAM_0 size: 0x4ff00 unused: 0x4ff00 max hole: 0x4ff00
undefined first referenced
symbol in file
gCacheConfig C:/ti/mcu_plus_sdk_am243x_09_01_00_41/source/kernel/nortos/lib/nortos.am243x.r5f.ti-arm-clang.debug.lib<CacheP_armv7r.obj>
error: unresolved symbols remain
error: errors encountered during linking; "sbl_keywriter.debug.out" not built
tiarmclang: error: tiarmlnk command failed with exit code 1 (use -v to see invocation)
makefile:136: recipe for target 'sbl_keywriter.debug.out' failed
gmake: *** [sbl_keywriter.debug.out] Error 1
Hi Hong,
otp_keywriter_am243x_09_00_00-windows-installer.exe is compatible with MCU+ SDK 09.00.00 release.
Can you please try with the compatible release version of SDK?
Tanu.
Hello Tanu,
I already tried SDK 09.00.00 release which did work and keywriter project builded it sucessfully, but we don't expect that the new release would break the keywriter project.
TI suggests keeping updated with the latest SDK release for bug fixes and other new features, but the latest SDK does break the previous project like this sbl keywriter project, what we should do to move forward? Switch back to 09.00 SDK from 09.01 instead?
Hong
