AM2634-Q1: Public keys used to certificate HSM run-time firmware
Part Number: AM2634-Q1
Hi BU experts,
Customer wants to know 2 things:
1. if they want to use their own keys to certificate the HSM run-time firmware, what should they do? And the keys should be shored into "TI Root Key Set" location or "Customer Root Key Set" location? I.e. which key set is used by HS-SE type HSM ROM codes, can it adjust to use custom root key set?
2. if it only supports that "TI Root Key Set" to certificate their HSM run-time firmware, how can they generate the certificate by their own, or need to send the image to TI?
Please help clarify the above problems.
Thanks & Regards,
Will
