Part Number: LAUNCHXL-CC1312R1
Hi there,
I am trying to build an application modeled after the bim_dual_onchip sample (No RTOS/TI Clang flavor).
I have implemented a secured BIM, and 2 instances of the demo app. I can use my own key pair to sign the FW images and have the BIM validate them.
But I need to relocate image A from 0x0002E000 (défault location ) to 0x00024000. I can do that by adjusting IMG_A_FLASH_START in the linker command file, and right there, I read the following notice;
/* Note that if the start address is changed, you must also change the reset */
/* vector address (m3Hwi.resetVectorAddress) in the TI-RTOS .cfg file. */
What are exact the name and location of this cfg file ? I can see multiple .cfg files in my SimpleLink SDK directory, witch define "m3Hwi.resetVectorAddress" , but I cannot find a link from my project to any one of them.
And assuming I identify and update the right one , will the change be taken into account next time I build my app, or do I have to take extra steps before ?
As it stands, my firmware does get relocated to 0x24000, but signature verification fails because of wrong data in the OAD imge header . (imgEndAddr and len are incorrect)
Thanks in advance for your support
CRE
